Power windows nightmare #796051 03/11/07 06:40 PM
BigHornE Offline OP
OK it's not really a nightmare, but one of my power windows is toast. The window stopped going up or down, and I finally got around to taking the door apart and looking inside. Yikes.
It seems the cable that actuates the window is jammed up, and a little white plastic cable run broken. I tried what I could, but nothing did anything, so for now duct tape is the only thing keeping the window up.
Can these be fixed, or is it common to get a whole new door at a junk yard or something?
BH
Re: Power windows nightmare [Re: BigHornE] #796052 03/11/07 08:11 PM
josh93rodeo Offline
I had the same problem with the cable and broken white plastic peices, I just replaced the window regulator that is complete with the track,cable, ect. Cost about $100 and about an hour to instal. I ordered from an online parts store.
93 Rodeo 4x4 3.2 auto
Tinted Windows
SuperWinch hubs
Full Kenwood audio system
Indy4x 3" lift, SS brake lines, HD tie-rods, DOR diff drops & UB skidders, Procomp ES3000's
Re: Power windows nightmare [Re: josh93rodeo] #796053 03/11/07 09:32 PM
BigHornE Offline OP
That doesn't sound so bad, but how did you get 'in there' to install all the bits and pieces? I can barely fit my fingers in there. I'm sure there must be a trick, because my bleeding knuckles were pretty useless.
BH
Re: Power windows nightmare [Re: BigHornE] #796054 03/12/07 10:45 PM
TrooperMark Offline
I too have had the same problem. As I recall it didn't take very long to replace either. Also paid under $100 shipping included.
1995 Trooper LS (OME Coils & 2" spacer, Rancho 9000, Nitto Terra Grappler 34", K&N, ARB Snorkel, Calmini Rear Bumper) In garage (9000 winch, custom S. America winch bumper, Delta Cams, Tera-Low 3.07)
Re: Power windows nightmare [Re: TrooperMark] #796055 03/16/07 03:01 AM
9
94redrodeo Offline
Its not as bad as it seems once you dive into it. You can get a chiltons manual to help you along.
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6043 MB (Peak: 0.6687 MB) Data Comp: Off Server Time: 2026-07-13 18:30:16 UTC
