Any Tips on Buying a Diagnostic Tach for 22RE? #796180 03/12/07 12:18 AM
matts Offline OP
I need to buy a tachometer for working on the 22RE. Anything special to look out for? Do the old kind that came with a dwell meter tend to work with the 22RE? -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: matts] #796181 03/12/07 02:05 AM
dcg9381 Offline
There isn't any way you can set the dwell with a 22RE. It doesn't have points.
For a tach, I'd assume you could go old school on it - any diagnostic tach that senses voltage upon grounding the coil will work.
22REturbo.net
1988 4Runner
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: dcg9381] #796182 03/12/07 02:19 AM
matts Offline OP
Thanks. I knew that about the dwell and no points in the 22RE. <img src="/forums/images/graemlins/drunk.gif" alt="" /> Most of the used tachometers I see for sale have a dwell meter and tach combined. I just need the tach function and I don't want to buy a Snapon/Bluepoint meter for $250. If an old school tach will do the job I may get what I need for much less (like $10) <img src="/forums/images/graemlins/lol.gif" alt="" /> . -- Matt
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: matts] #796183 03/16/07 09:31 AM
VanillaTHUNDA Offline
Yeah, I actually just use my DVOM. Works great!
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: VanillaTHUNDA] #796184 03/16/07 04:40 PM
matts Offline OP
You'll need to expand on that a little. I'm going to guess that 'DVOM" means digital volt ohm meter. Is that right and how does it work? -- Matt
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: matts] #796185 03/16/07 04:47 PM
4Crawler Offline
I have an old dwell/tech/ohm meter from Sears that still works fine. Has a big dial and a 0-1000 low RPM range and a 0-10000 high RPM range. Or now I recently replaced my old timing light with a new one w/ intergrated digital tach and timing advance display.
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: 4Crawler] #796186 03/16/07 06:00 PM
matts Offline OP
Exactly! I see tach/dwell combo's going for pennies on eBay. I'm waiting for an industrial quality unit at a bargain price. Something with a large meter and switches for 4/6/8 cylinders and high and low range rpm.
I've seen new tachs that have an inductive pickup. That should work with any engine that has sparkplug wires. The idea of a timing light with inductive pickup and a built-in tach makes good sense. -- Matt
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: matts] #796187 03/16/07 07:37 PM
Yeah, that's what it stands for. Turn the dial on the DVOM to "4cyl" and attach the positive lead to the coil negative post, then ground the DVOM negative lead to a decent ground and BAM! You've got RPM. Works great for me.
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: VanillaTHUNDA] #796188 03/17/07 12:04 AM
toowacky Offline
So I guess that implies that you need an automotive specific DVOM, like the Actron CP7677... I think Matt was asking (and I was wondering) if there was any way to use a generic DVOM as a tach....
1988 4Runner 22R-E W56
1989 4Runner 22R-E A340
1995.5 Rodeo 3.2L 5spd
Re: Any Tips on Buying a Diagnostic Tach for 22RE? [Re: toowacky] #796189 03/17/07 04:26 AM
matts Offline OP
Exactly! -- Matt
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6430 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-11-03 13:33:47 UTC
