Engine Tranny Match-up
#796206
03/12/07 01:51 AM
Does anyone know the largest motor by Mitsubishi or any other that will match the existing 4-speed Automatic tranny in my 1990? will the newer 3.5 etc... match up?....Sorry if this is already an asked question, I looked in the forums and didnt see it, Thanks! <img src="/forums/images/graemlins/smile.gif" alt="" />
1990 LWB 3.0L With 33/12.50's K&N 251k Miles
Re: Engine Tranny Match-up
[Re: Trail_Maker]
#796207
03/12/07 05:39 PM
It will mate, but you will have fun with the electronic part of it, if you're using a 3.5l Auto trans.. I think up until 93, you're ok as far as it being the same trans. All the ones after that are computer controlled. Someone correct me if I'm wrong.
Brendan
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: Trail_Maker]
#796208
03/13/07 12:13 AM
The largest that we got is the 3.8 in the 2003 and newer Montis. It has a more elaborate managment system using drive buy wire so you will want the electronics from an earlier 3.5 for a swap.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5953 MB (Peak: 0.6486 MB) Data Comp: Off Server Time: 2026-06-17 04:17:52 UTCValid HTML 5 and Valid CSS
