Broken bolt extractors - don't #796315 03/12/07 02:34 PM
BigSwede Offline OP
I bought a set of Irwin bolt extractors (the tapered, fluted, left-hand thread things where you drill a hole into the bolt stub and insert the extractor and crank it lefty loosey) a while ago...so far I have broken 3 of the 5, the others are going in the trash. Not recommended. Maybe other brands are better, but somehow I doubt it.
Serenity now!
Re: Broken bolt extractors - don't [Re: BigSwede] #796316 03/12/07 04:27 PM
lttlbddy Offline
I've had mixed luck with bolt extractors. Larger sizes with good access to the bolt seems to help. The left hand drill bits are the best though. Often times loosening up the broken bolt while drilling it out, then the extractor works well.
Re: Broken bolt extractors - don't [Re: lttlbddy] #796317 03/12/07 04:44 PM
onebadtrooper Offline
Yeah you have to only use the good brand one, My dad thought me to never use the cheap ones, they'll break every time.
I'm not sure what brand he gets, he gets them through his work(bis jet engine mechanic)
Re: Broken bolt extractors - don't [Re: onebadtrooper] #796318 03/12/07 05:07 PM
Starchild Offline
I broke a Craftsman extractor on a pretty large bolt. Getting the pieces of extractor out of the still stuck bolt was a huge PITA.
I'll skip them next time.
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Broken bolt extractors - don't [Re: Starchild] #796319 03/12/07 05:55 PM
BigSwede Offline OP
Yeah, that's the real problem. If they could be drilled out then I wouldn't mind so much, but that hardened steel is very difficult to drill.
The second and third one I broke were on a bolt I had drilled all the way through, so I was able to punch the broken pieces out from behind, otherwise I wouldn't have even tried the extractors.
Then I drilled the hole out bigger and tried the largest extractor...it didn't break but I twisted the head of it a little and the wrench got a groove in it before I gave up...I'm just gonna drill it all out and through-bolt it.
Serenity now!
Re: Broken bolt extractors - don't [Re: BigSwede] #796320 03/14/07 08:47 PM
desertbenny Offline
If the bolt/stud is above the surface,Get a set of the craftsman extractors that look like nuts with reverse threads. They actually dig into the stud and it comes right out. No drilling, no breaking bits. I've found with this type of tool you get what you pay for.
86' Trooper, 2.3, 31" wild countrys, pro comp shocks.
Re: Broken bolt extractors - don't [Re: BigSwede] #796321 03/15/07 03:29 AM
Mr. Mojo Offline
I'm not saying mine won't end up like yours but I have extracted many a bolt with my set of Irwins and so far so good. How long is a while ago ?
98 Rodeo
00 4Runner
--I swear its just over the next pass !!--
--"Courage is something you can't be afraid to have." - Frank Burns
Re: Broken bolt extractors - don't [Re: Mr. Mojo] #796322 03/16/07 03:01 AM
BigSwede Offline OP
I bought 'em a few months ago...didn't use them until recently. All I can say is my he-man strength overwhelmed them before they did diddly to get the bolts out...every time.
Irwin is generally a cut above the cheap no-name stuff, which is why I bought them. Oh well.
Serenity now!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6247 MB (Peak: 0.7233 MB) Data Comp: Off Server Time: 2026-10-21 16:20:18 UTC
