Torque specs on steering arms
#796424
03/12/07 09:58 PM
just want to conform that. From my understanding (FSM)it says 80 foot pounds of torque on the arm studs. Also says 71 foot pounds???? I went with a high steer get and didn't get any instructions. As for the pitman arm....I gave it all I could to torque that done. Thanks, Mike
Re: Torque specs on steering arms
[Re: MnMsToY]
#796425
03/13/07 01:53 AM
just want to conform that. From my understanding (FSM)it says 80 foot pounds of torque on the arm studs. Also says 71 foot pounds???? I went with a high steer get and didn't get any instructions. As for the pitman arm....I gave it all I could to torque that done. Thanks, Mike I just re-read the FSM and could not find anything about 80 ft lbs. All I found was 71 ft lbs unless you have the ARP from FROR then Brian recommends 100-110 ft lbs.
"Serenity through Sobriety"
[Re: OOP'S]
#796426
03/13/07 03:03 AM
no arp studs all stock. Thanks...I will go with the 71. Mike
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5946 MB (Peak: 0.6489 MB) Data Comp: Off Server Time: 2026-06-17 04:07:49 UTCValid HTML 5 and Valid CSS
