front stabilizer shock #796467 03/13/07 01:38 AM
rodeo157 Offline OP
on my 95 rodeo 3.2 4wd i want to upgrade my stablilizer shock, but the stock one almost touches my oil filter. anyone do this mod and any clearance issiues with the oil filter.
95 rodeo 3.2 liter 5 speed 4 wheel drive. 2" lift. poly bushings. 2 1/4 manderal bent exhaust flow master muff. asin manual hubs, relocated ball joints, custom air intake system
92 rodeo 3.1 2wd auto (wifes)
Re: front stabilizer shock [Re: rodeo157] #796468 03/16/07 12:18 AM
rodeo157 Offline OP
you telling me all these wheelers have not upgrading the stabilizer shock
Re: front stabilizer shock [Re: rodeo157] #796469 03/16/07 12:27 AM
lttlbddy Offline
I was able to position mine so that it did not touch anything. It was close though.
The aftermarket one did not use any of the stock mountng locations, it had a mounting kit which gives you the ability to adjust each end a bit and rotate away from things.
Re: front stabilizer shock [Re: rodeo157] #796470 03/16/07 01:03 AM
strawmyers Offline
Isuzu Moderator
I took mine off 8 years ago and haven't missed it. Makes changing the oil filter less of a pain.
Sean Strawmyer
Re: front stabilizer shock [Re: strawmyers] #796471 03/16/07 01:23 AM
Jim_Paget Offline
A Rancho 5401 will work, or you can acheive the same performance enhancement by sending a check for a like amount to the either me or the charity of your choice.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: front stabilizer shock [Re: Jim_Paget] #796472 03/16/07 01:41 AM
rodeo157 Offline OP
thanks for the info, but im getting bigger tires, dont the stabilizer keep the wheels from moving in and out at higheway speeds. it did on my 4runner. also will 15x8 wheels fit or stick with 15x7 thanks
Re: front stabilizer shock [Re: rodeo157] #796473 03/16/07 02:35 AM
strawmyers Offline
Isuzu Moderator
If you have loose/worn steering or suspension components, they should be fixed or replaced as needed. Replacing toasted ball joints and tightening the steering box made my steering and handling 400% better. The idler arms are also known to cause issues when worn. Steering stabilizers are bandaid fixes for other issues. JMHO
Sean Strawmyer
Re: front stabilizer shock [Re: strawmyers] #796474 03/16/07 02:52 AM
9
94redrodeo Offline
I agree with strawmyers you dont need a stabilizer on IFS My trooper never even had one and it didn't seem any different than the rodeo,
Now on my 95.5 with the sas one steering stabilizer doesnt even do the job
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: front stabilizer shock [Re: 94redrodeo] #796475 03/17/07 03:21 AM
TrooperMark Offline
34.5 inch tires and see no need for stabilizer. Just make sure all the joints are ok...ie. ball joints, tie-rod ends, etc.
1995 Trooper LS (OME Coils & 2" spacer, Rancho 9000, Nitto Terra Grappler 34", K&N, ARB Snorkel, Calmini Rear Bumper) In garage (9000 winch, custom S. America winch bumper, Delta Cams, Tera-Low 3.07)
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6234 MB (Peak: 0.7265 MB) Data Comp: Off Server Time: 2026-10-26 05:33:37 UTC
