Re: body lift!!!!!!!!!!! [Re: 4Crawler] #796622 03/13/07 09:41 PM
drewdaddy Offline OP
2" sounds like a better option!! Anyone know what is the largest tires I can put on my 88. I am guessing 31 x10.50??? even though i would like bigger ones. i have a lot of questions being new to this. Can anyone point me in the direction of what size tires are stock on this truck (mine are different sizes) and where I can calulate what gears i will need with new tires??? I tried the search on here, but it doesn't seem to work very well (or it could be user error)
31x10.50 will fit stock:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
Gearing vs. tire size:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#DiffRatios
Steering shaft extension:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#RecircBallExt
- http://www.4crawler.com/4x4/ForSale/Docs/BodyLift_HowTo.shtml#RecirculatingBall
Thank you!!!!!!!!
88 P/U EFI 4x4... Stock for now.. 05 Corvette MN6 Z51 Package
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796623 03/14/07 07:12 AM
Myredyota Offline
I just put a 4Crawler 1" body lift on my truck last weekend. It was very easy to do by myself. He really has a well thought out product.
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796624 03/14/07 04:44 PM
grandeyota Offline
I've been running the FL mud with 35s on a 3" body lift. I have 33's I swap over for street driving (swampers wear out quick on the highway). I had the trim the front fenders and pound them back flat. Also got a set of extended rear shackles to clear the back some more.
I've run a few different gear ratios (4.10, 4.56, 4.88, 5.29) and I like the 4.88s the best for my 33-35s.
A locker will get you much further than a bigger tire.
Fur clog in the sausage grinder
Re: body lift!!!!!!!!!!! [Re: grandeyota] #796625 03/14/07 06:08 PM
[quote]I've been running the FL mud with 35s on a 3" body lift. I have 33's I swap over for street driving (swampers wear out quick on the highway). I had the trim the front fenders and pound them back flat. Also got a set of extended rear shackles to clear the back some more.
Thanks for the information, did you install the body lift yourself?? If so, was it a pain to install 3"?? Did you have to move a lot with the extra lift!!!
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796626 03/14/07 06:30 PM
grandeyota Offline
The body lift was on the truck when I got it. <img src="/forums/images/graemlins/notooth.gif" alt="" />
I've helped a few other guys install body lifts on their trucks and it went pretty smooth each time.
Re: body lift!!!!!!!!!!! [Re: drewdaddy] #796627 03/17/07 08:14 AM
Snowtoy Offline
I cleared 33's on 15x8's on this '86 with a 2" BL.
I hammered the inner body seam and the tires only rubbed a little(not enough to cause harm) when at full lock when turning into a driveway.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6194 MB (Peak: 0.7227 MB) Data Comp: Off Server Time: 2026-06-22 14:15:22 UTC
