engine dies. #796841 03/13/07 10:31 PM
tking Offline OP
after running 15 mins it dies changed fuel filter still dies 89 jeep 6cyl
engine dies why
single choice
Votes accepted starting: 03/13/07 05:00 AM
You must vote before you can view the results of this poll.
Re: engine dies. [Re: tking] #796842 03/13/07 10:50 PM
BigJim Offline
And then??? Ok so it dies.. are you still in the driveway? Does it restart? What are it's dying gasps? Popping, crackeling? Smoking?
Enlighten us.
Re: engine dies. [Re: BigJim] #796843 03/21/07 04:04 AM
9
93yj Offline
Not to sound rude, but why do so many people assume "fuel filter" when a vehicle dies? That filter would have to be plugged shut in order for the engine to not receive fuel, which is HIGHLY unlikely. That's the last thing I'd consider.
The coil could be overheating, which is a common problem with faulty ignition modules. No spark = no start, obviously. They overheat and literally shut off.
Re: engine dies. [Re: tking] #796844 03/22/07 01:54 AM
melody Offline
if there is no spark, most likely causes would be a failed ignition module. if the engine won't crank, you are probably dealing with a jeep starter or battery problem.
PHP: 7.4.33 Page Time: 0.008s Queries: 18 (0.005s) Memory: 0.6138 MB (Peak: 0.7166 MB) Data Comp: Off Server Time: 2026-06-19 23:24:18 UTC
