chirping montero #796845 03/13/07 11:34 PM
oewii Offline OP
My '88 SWB Montero is making a chirping sound that appears to be coming from the rear end or driveshaft. It starts when the vehicle warms up and increases in speed as I go faster. I jacked up the Rear and checked but no noise. After I put it back on the ground and drove it, it made the noise again. I'm concerned about driving very far until I figure it out. Thanks in advance for any help.
1988 montero
31X10.50X15 Pro Comp A/Ts on 15X8 Rock Crawler 97s
Weber conversion with carter fuel pump. Roof rack in progress.
Re: chirping montero [Re: oewii] #796846 03/13/07 11:57 PM
8
89IsMine Offline
Check the dust shield around where the driveshaft mates with the transmission (or is it the transfer case? Hmm. Can't remember now...). Looks kind of like a tin can. Mine was loose and and would rattle against the spinning drive shaft, although it sounded more like I was dragging tin cans behind me on a string than a chirp.
Eric W.
Re: chirping montero [Re: oewii] #796847 03/14/07 12:04 AM
Suspension noise? When not in drive, does this happen when the suspension moves & engine is off or only when the engine is running?
Eric W.
Eric, IIRC you're talking about the xcase output shaft dust shield. The tranny is connected directly to the xcase w/out any exposed shaft in between.
Re: chirping montero [Re: off-roader] #796848 03/14/07 12:44 AM
8
89IsMine Offline
Yup, that's correct. Thanks for clarifying! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Eric W.
Re: chirping montero [Re: 89IsMine] #796849 03/14/07 12:29 PM
Y
yankneck696 Offline
Any time I have ever heard chirping from a rear drivetrain, I have replaced all U joints.
Never heard chirping again.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: chirping montero [Re: yankneck696] #796850 03/14/07 01:39 PM
pmontero Offline
They do that when they want to go play in the mud. They get louder and also start whining if you ignore them... take him out on the trail... <img src="/forums/images/graemlins/wink.gif" alt="" />
My vote is the u-joints as well. Wiggle and rotate the driveshaft. If there is any play at all in it, they need to be replaced. If you haven't changed the fluid in the rear diff, transfer case and transmission, you may want to consider doing it as well.
Pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6132 MB (Peak: 0.7004 MB) Data Comp: Off Server Time: 2026-06-21 20:22:41 UTC
