3.0 L AC idle speed question #796873 03/14/07 01:17 AM
8
89IsMine Offline OP
I looked for an answer/troubleshooting guide for this in the FSM, but didn't find anything. I notice that when I switch my A/C on that the idle speed does NOT jump up to 900 rpm as specified in the FSM, but instead drops by ~100 rpm from standard idle. I can hear the compressor clutch kick in and I'm definitely getting cold air out of the vents so I think there's enough R12 in there to possibly rule out a low refrigerant condition. The A/C was working great last summer -- idle speed kicked up when the compressor clutch engaged just like it should. Any A/C gurus out there who know the cause of this or can suggest a course of action for troubleshooting it?
Thanks!
Eric W.
Re: 3.0 L AC idle speed question [Re: 89IsMine] #796874 03/14/07 03:26 AM
4xmonty Offline
Read this http://www.stealth316.com/2-isc-iac.htm
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: 3.0 L AC idle speed question [Re: 4xmonty] #796875 03/14/07 07:22 AM
8
89IsMine Offline OP
Thanks for the link, Russ. Very interesting reading. The ECU has to take some input signal though in order to bump the ISC up to compensate for the increased load from the compressor, right? What is it that signals the ECU? Or am I missing something obvious here?
Eric W.
Re: 3.0 L AC idle speed question [Re: 89IsMine] #796876 03/14/07 03:59 PM
W
Winston Offline
Generally, it is not the input signal that fails, it is the ISC motor that fails. You turn on the AC, the ECU tells the ISC to bump up the Idle speed and the idle speed does not bump up, because the ISC is broken.
Your idle speed drops when you turn on the AC because of the extra load on the engine.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: 3.0 L AC idle speed question [Re: Winston] #796877 03/14/07 05:45 PM
8
89IsMine Offline OP
Interesting. Thanks Winston! I suppose that might also explain the issue I posted about some weeks ago where coming off deceleration with the lights on the rpms drop down to about 400 then bump back up to ~700.
Eric W.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6095 MB (Peak: 0.6751 MB) Data Comp: Off Server Time: 2026-05-29 22:17:28 UTC
