Hub Mechanics Question #796916 03/14/07 04:00 AM
PitterCol Offline OP
How are the auto hubs on nineties Monteros activated? Vacuum, electric or none of the above?
Re: Hub Mechanics Question [Re: PitterCol] #796917 03/14/07 04:24 AM
Grasscat Offline
none of the above
Just put it in 4 wheel drive and it's engages.
Most of the answers to your questions are in the owners manual. Did you get one from the dealer?
Michael j
TreadLightly! Trainer
Re: Hub Mechanics Question [Re: Grasscat] #796918 03/14/07 01:48 PM
My hub question is not addressed in the manual. The "none of the above" response surprises me because I thought all "automatic" hubs require some force to activate them. For example my ?93 Dodge Dakota uses vacuum to operate the hubs and my ?06 Mazda B2600 uses an electrical signal.
Re: Hub Mechanics Question [Re: PitterCol] #796919 03/14/07 02:03 PM
sparkem Offline
I think the twisting action of the CVs turn something inside to lock.
I like my manual hubs.
Re: Hub Mechanics Question [Re: sparkem] #796920 03/14/07 02:14 PM
TommyM Offline
If it's like our USA 1992+ (Gen II) models, the hubs are permanently "locked." There is a "center axle disconnect" that is vacuum operated, and actuates when you engage 4wd. It basically disconnects one of the CV axles from the center diff.
90 LWB Montero, 270k, 265/75R16, 16x8 ARE Bajas, Budget Lift, Towbar, Aux Brakes (towed with camper), Jotto Desk, remote oil filter
92 bone stock base model beater
Parting out 4 more
Re: Hub Mechanics Question [Re: TommyM] #796921 03/14/07 03:55 PM
W
Winston Offline
The Gen II and III hubs are always engaged. The front Half-shafts are always spinning. As noted above there is a vacuum actuated clutch that dissengages the front differential. However, the spider gears in the differential are always spinning too.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6116 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-10-24 03:21:48 UTC
