belts on 95 sr
#797182
03/15/07 05:22 AM
i gotta change the belts and lookin at it i cant tell if there is an easier way to do it without taking the radiator out any ideas???
1988 swb montero/pajero 1995 sr montero
Re: belts on 95 sr
[Re: mountain_warrior]
#797183
03/15/07 05:26 PM
If you need more room once the tension is relieved remove the fan.
1995 Montero SR 1999 Montero 1974 Ford Bronco
Re: belts on 95 sr
#797184
03/15/07 05:41 PM
You do not need to remove the radiator to replace any of the belts. It is possible to remove the fan and fan shroud without removing the radiator.
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5941 MB (Peak: 0.6471 MB) Data Comp: Off Server Time: 2026-05-29 15:00:56 UTCValid HTML 5 and Valid CSS
