Tire size on stock 89 SWB #797210 03/15/07 01:55 PM
Dan1171 Offline OP
I have done some research and see a lot of different answers to this question. I am going to purchase new tires and would really like to move up from the weak 225/75/15. I have not done the lift and still have the stock rims. I am planning on doing the lift later on, but for now it is on hold. My truck is a 89 SWB 2.6 liter. I do drive this vehicle about 50 miles a day, but do go into the woods some also. No real mudding, not until I get me another vehicle.
Re: Tire size on stock 89 SWB [Re: Dan1171] #797211 03/15/07 02:10 PM
pmontero Offline
Hi,
31x10.5x15 will fit on the stock rims comfortably. I ran them both on SWB and LWB 3.0 V6 Gen I trucks but I haven't had any experience with the 2.6 with this size tire. However, that is what I will be running on my '87 Montero SWB but it will have the 2.3 turbo diesel in it.
Pmontero
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
Re: Tire size on stock 89 SWB [Re: pmontero] #797212 03/15/07 02:14 PM
Dan1171 Offline OP
Thanks for the info. Do you have yours lifted?
Re: Tire size on stock 89 SWB [Re: Dan1171] #797213 03/15/07 04:22 PM
Dan no lift is necessary for 31's. I run 32's on a 15x8" rim with a neutral offset and that's w/out any lift... it did shave 1/32-1/8" off the end of the rubber bumper cap automagically though. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Keep in mind mine is the 3.0L v6 so your performance (not fit) may vary.
Re: Tire size on stock 89 SWB [Re: off-roader] #797214 03/15/07 07:06 PM
Dan1171 Offline OP
I think the stock rim is a 15x6 and I would just worry about scrubbing when you turn. It would look a lot better with 31's than with those 225's.
Re: Tire size on stock 89 SWB [Re: Dan1171] #797215 03/15/07 08:19 PM
Without question!
Re: Tire size on stock 89 SWB [Re: off-roader] #797216 03/15/07 08:40 PM
DRaider90 Offline
I moved from 215's -> 235's -> 31x10.5's . I will say the 31's look much better than the previous 2.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: Tire size on stock 89 SWB [Re: off-roader] #797217 03/15/07 08:41 PM
I'm running 33's on my 87 Raider. I trimmed the inside front of the wheel well with a sawsall pretty judiciously and let the tires take care of the bumper end. This is my daily driver with a minimum 50 miles a day, sometimes 200 as it is my work truck. The terrain varies from city/highway to 2-track trails and haul roads on earthwork project. I'm running no lift, no cranked torsion bars, 10" wide wheels in the back and 8.5" in front with 4" backspace. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Tire size on stock 89 SWB [Re: DRaider90] #797218 03/15/07 09:02 PM
Dan1171 Offline OP
Are you still running your stock 15x6 rims?
Re: Tire size on stock 89 SWB [Re: Dan1171] #797219 03/16/07 03:06 AM
You could run 33x10.5" on the stock 6-inch rim... <img src="/forums/images/graemlins/cyclops.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6390 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-06-07 08:34:14 UTC
