Tundra towing question #797484 03/16/07 06:54 AM
YOTA88 Offline OP
just wondering if anyone else is towing their wheeler with a Tundra. i'm looking for opinions/ideas on air ride and/or overload springs for rear support. my Tundra tows just fine but it's time to upgrade the rear suspension(starting to sag a little) since i can't upgrade to the new 5.7 Tundra yet <img src="/forums/images/graemlins/smile.gif" alt="" />..
here's a pic. it didn't sit this low the first few times i towed my rig with it but it's obvious that the weight it starting to take it's toll on the rear springs.
Thanks in advance for any input.
SAS88TOY, caged, lockered, Longfielded, etc. etc. etc. blah blah blah!!!
2005 Tundra Quadcab.
Re: Tundra towing question [Re: YOTA88] #797485 03/16/07 03:15 PM
garym Offline
I occasionally tow a snocat with my F250 at work so I went with the air bags. You can stiffen them up pretty good and let them back down with normal loads so it doesn't kill your back. I got them at Schwabs. 2 yrs so far and no problems.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Tundra towing question [Re: YOTA88] #797486 03/16/07 11:39 PM
ErikB Offline
Toyota Moderator
A friend of mine put some air bags on his Tundra for towing his wheeler too...
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB78&Number=341151
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB78&Number=232482
He eventually traded it in for a Dodge 2500 CTD though and seems much happier with its towing/braking performance and fuel mileage.
I believe 4Mogger on PBB is towing w/ his Tundra as well.
http://home.4x4wire.com/erik
Re: Tundra towing question [Re: ErikB] #797487 03/17/07 02:46 AM
YOTA88 Offline OP
thanks guys <img src="/forums/images/graemlins/kewl.gif" alt="" />!!! that write up on the airbags was all i needed to see. i was pretty much leaning towards bags from the beginning but i thought i'd get a little more info before spending the dough.
Re: Tundra towing question [Re: YOTA88] #797488 03/25/07 02:40 AM
U
usmcracing Offline
For those of you that are towing your wheeler with your Tundra. What kind of fuel mileage are you getting? Did you have any problems with the trans, over heating, slipping? I know I'll have to beef up the rear springs to handle to extra load. I'll be towing a 91 4door SAS'd 4Runner.
I'm looking at a used 2000 x-cab 4wd with 145k miles for $6900. Owner claims it to be in the great condition.
Thanks
Re: Tundra towing question [Re: usmcracing] #797489 03/25/07 04:35 AM
Jake97T Offline
is that a V8 tundra or 6? if its the 6, id definetly put a big old tranny cooler in it. great price on a Tundra either way.
Re: Tundra towing question [Re: Jake97T] #797490 03/25/07 10:32 PM
U
usmcracing Offline
Its a 4.7L v8. I think I'm going to pass on it cause I'm not liking what I'm hearing about towing issues. Thanks
Steven
Re: Tundra towing question [Re: usmcracing] #797491 03/25/07 10:57 PM
H2O_MAN Offline
Steven
The towing issues that I know of involve owners that don't.
They don't turn off the OD when towing, they don't have a cooler and they don't keep the transmission fluid fresh and clean. HTH ~
Air bags and a Hellwig are must have towing gear.
Re: Tundra towing question [Re: H2O_MAN] #797492 03/26/07 01:49 AM
Jake97T Offline
What transmission does the V8 early Tundra have?
Re: Tundra towing question [Re: YOTA88] #797493 03/31/07 02:41 AM
4
4Mogger Offline
You don't need to do anything to your Tundra. Just need a quality brake controller (prodigy) and a weight distributing hitch. I like the soft springs and with the WD hitch it rides awesome. I have plenty of power to hold hills at 70 with well over 13K gvw. I get about 12-13 mpg when towing.
I have the same rig you do...'05 Grey DC limited 4X4
'05 Tundra DC Limited 4X4, Nitto 265/70's.
'94 4Runner on Mogs, locked up, Hummer double beadlocks, 40"MTR's, Marlin Ultimate, CTIS, yada, yada...
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6368 MB (Peak: 0.7607 MB) Data Comp: Off Server Time: 2026-06-17 01:40:25 UTC
