OK need some help here.
#797538
03/16/07 07:58 PM
1987 toyota 4x4 22re. I parked my truck for about 2 weeks. Went out to fire it up and nothing. Lights worked, some things did not. I found out that the 80 amp fuse next to the battery had blown. How did that happen? Anyways throw a new one in and it fires right up. Let it run for about 15 minutes. Shut it off. Next week i need my truck, nothing again, this time no lights no nothing. I checked all the fuses by my battery, they all are fine. I havnt checked the ones on my kick panel but will. How do i keep popping fuses when my truck is just sitting?
Re: OK need some help here.
[Re: Omega Supreme]
#797540
03/17/07 01:46 AM
Ok so i went and checked out all of my fuses. A ok. What could this be, a bad ground, its been sitting in the garage for a month, it started a week ago. My battery has juice, i cant even get my clock to come on. Any help would be great. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Omega Supreme]
#797541
03/17/07 02:17 AM
some times just "rotating" / "moving" the positive post clamp on the battery works ..
sometimes there can be a build-up/neg clamping on the post... IF the battery is left in there .
[Re: CJM]
#797542
03/17/07 02:31 AM
Make sure you test the 80A fuse with a multi-meter. I've had it blow before and it still looked perfectly ok. As to why your're blowing fuses, I have no idea. I would imagine some sort of a short somewhere <img src="/forums/images/graemlins/confused.gif" alt="" />
-Scerb
[Re: Omega Supreme]
#797543
03/17/07 04:19 AM
THere should be a fusible link before the under hood fuse box, check to see id you have *any* power at the box.
Once you find the problem start checking with the ohm meter to try & isolate what's causing it.
Dave
[Re: Davepet]
#797544
03/17/07 08:34 PM
J Roll Me Over
A common short location causing the 80 amp fusible link to blow is the o2 sensor wire melting on the exhaust. Look there first.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6186 MB (Peak: 0.6926 MB) Data Comp: Off Server Time: 2026-05-29 23:57:04 UTCValid HTML 5 and Valid CSS
