Rad Fluid explosion! #797701 03/17/07 03:38 PM
Fleabag Offline OP
My truck sprung a leak somewhere near the back of the motor. I was driving for 45 mins or so and when I got home, I put the truck in the garage and when I turned it off, rad fluid spewed out from somewhere near the back of the motor by the firewall.
I looked in my Haynes book and the only thing that I could think of being the culprit would be one of the lines going into the cab for the heater core. I couldnt really see it from all of the steam.
So, now I have replace one of these blown lines, but I guess flushing the core to see where the block it. The temperature guage never went above 1/2 level.
Is it possible to have a plugged core to make one of these lines burst, or was it just one of these line giving away to age that could have caused this?
Strangers have the best candy
Re: Rad Fluid explosion! [Re: Fleabag] #797702 03/17/07 03:47 PM
The heater hose from the intake to the firewall is a common failure part, the original factory hose was good for about 3 years. I find Gates brand to last much longer, but not forever.
Re: Rad Fluid explosion! [Re: OldColt] #797703 03/17/07 03:56 PM
Fleabag Offline OP
If wasnt -10 out.. I would be ripping into my engine looking for that hose... but thanks for the info of where to look!
Re: Rad Fluid explosion! [Re: Fleabag] #797704 03/17/07 04:29 PM
My ford did the same thing. It was a super cold day in Colorado and my thermostat was frozen. I started my truck let it run for a while to warm up then when I went to drive away the hose burst and antifreeze went everywhere.
Dont know if this is helpful but it might have something to do with the outside temp.. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Rad Fluid explosion! [Re: cmonty72] #797705 03/17/07 05:26 PM
Fleabag Offline OP
Bad thermostat too? Hmm.. I just replaced it a month ago.
Re: Rad Fluid explosion! [Re: Fleabag] #797706 03/17/07 05:35 PM
Not exactly "bad" , just frozen. The antifreeze was not quite rich enough. It really only takes a little bit of ice to prevent even a new thermostat from opening.
Re: Rad Fluid explosion! [Re: cmonty72] #797707 03/17/07 06:00 PM
toddstidham1 Offline
Sounds more like an old hose and it burst at the weak point. More then likely a few minutes after shutdown when the water temp and pressure tends to rise due to heat soak. I've had my share of burst hoses on numerous cars and trucks...usually right after I purchase replacement hoses but before i get a chance to put them on! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Rad Fluid explosion! [Re: toddstidham1] #797708 03/17/07 09:16 PM
Jamez Offline
Same thing happened to me in my grampa's Raider. I noticed the temp creeping up and when I came to a stop the steam showed up. His hose apparently had a bulge it in, but nobody noticed since its easily overlooked.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: Rad Fluid explosion! [Re: Jamez] #797709 03/18/07 02:40 PM
5
5th Offline
Mine had pinhole leak in one of the freeze plugs.
85 Montero 2.6L Standard, SWB, A/C, BSE
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6294 MB (Peak: 0.7324 MB) Data Comp: Off Server Time: 2026-11-02 23:31:35 UTC
