Manual trans wont go into any gear #797845 03/18/07 04:25 AM
triplediamonds Offline OP
Not familar with transmissions and need some advise. I have a v6 transmission that wont shift, just has side to side (neutral)Dont know what to do.
88 Mitsu Van (L300)
90 Mitsu Eclipse GSX
95 Mitsu Montero SR w/285/75/16 torsion bars cranked about 1.5"
04 Mitsu Lancer Ralliart
81 Datsun 280ZX
96 Dodge Cummins Turbo Diesel (316hp/815ft.lbs)
Re: Manual trans wont go into any gear [Re: triplediamonds] #797846 03/18/07 04:53 AM
cktoy Offline
I would start by taking the shifter stick outr,and see what that looked like in there.but I,m by no means a tranny mech.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Manual trans wont go into any gear [Re: triplediamonds] #797847 03/18/07 10:41 AM
DRTDEVL Offline
Check the fluid in the clutch master cylinder
Re: Manual trans wont go into any gear [Re: DRTDEVL] #797848 03/18/07 03:00 PM
canuck Offline
Second that, check the clutch hydraulics. Check under the peddles to see if there is any brake fluid (brake fluid is used in the clutch master cyl). If there is any fluid it means your clutch master is leaking. Cheap and easy fix if this is the case.
Keep the Shiney Side up. Support our troops.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6549 MB) Data Comp: Off Server Time: 2026-06-07 09:05:47 UTC
