Page 1 of 3 1 2 3
On keeping mice out #798063 03/19/07 03:25 AM
Tglow Offline OP
I was away from my T100 for several months and mice got in under hood. Upon taking off air flow vents under windsheild wippers, I found a huge nest even though the vents have a screen backing. After taking out interior fan motor and cage, I ran water from outside vents and collected it inside on the husky floor liners. It took about 20 minutes of running water to get a all that debris out. They also made their way into the air filter box.
Any suggestions how to keep them out?
<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: On keeping mice out [Re: Tglow] #798064 03/19/07 03:57 AM
BamZipPow Offline
Sorry to hear you have a case of mice. <img src="/forums/images/graemlins/frown.gif" alt="" />
You could hire a cat... <img src="/forums/images/graemlins/wink.gif" alt="" /> Not sure how you would keep vermin out of yer truck...too many bogus stuff out there.
Re: On keeping mice out [Re: BamZipPow] #798065 03/19/07 04:06 AM
Tglow Offline OP
in my fustration i was thinking along the lines of pulling the fan motor when away and sealing a 12 volt paper shredder to the opening and priming it with some cheese... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: On keeping mice out [Re: Tglow] #798066 03/19/07 04:34 AM
BamZipPow Offline
Found this...
Mice have a natural aversion to mint, and will generally avoid it. Plant it around the exterior of your house as a deterrent as well as potting some around your home. Not only will they keep mice away, but theyÆll freshen the air as well. Ahhh. Spearmint seeds can be had in garden centers or ordered online
So you might try some mint extract or plants inside yer truck and other areas that they got into... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: On keeping mice out [Re: BamZipPow] #798067 03/19/07 04:53 AM
kewlynx Offline
Gotta watch mint; that stuff can get pretty invasive.
Might want to make sure the area around the truck stays mowed if you aren't opting to put it in a storage lot.
Also when handling vermin middens, wear disposable gloves and a dusk mask; dem dere things carry disease.
Also lay out some fresh clothes before you start, so your chore clothes can go straight into the wash when you're done.
**ubi apis- ibi salus**
Re: On keeping mice out [Re: Tglow] #798068 03/19/07 06:03 AM
engnbldr Offline
>>>*I have experience with mice. I set traps and they rob the traps, my cats are so fat they won't even look up at a bird, I tried plugging up all the holes to no avail.
I just take my Corvette to the dealership, have them evicted, then drive it home for another load.
I figure someday I will have all the mice at the dealership and none left at home.
I hate mice!....*EB
*Beats the he** outa me!....*LOL**...
Re: On keeping mice out [Re: engnbldr] #798069 03/19/07 07:46 AM
Creeper Offline
I read somewhere that a guy stuffed mothballs under his hood in an attempt at keeping mice out. Or maybe that was moths...?
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: On keeping mice out [Re: Tglow] #798070 03/19/07 04:10 PM
E
eppoh Offline
There is an air filter on these trucks? Where is it?
I have the same trouble with a light plane in a hangar with a concrete floor.
What I did to keep them out is to get some thin sheet metal, like 30 ga. One piece for each wheel. Have it cut long enough so you can bend it in a rectangle and place it around each tire. It will have to be tall enough so the mice cannot jump over it, but of course must fit under the bottom
of the fender. This makes a un- climable barrier for mice around the only part of the truck touching the ground.
If it is sitting on dirt or grass, it probably won't work- they'll dig under the metal.
Where is that filter?
Re: On keeping mice out [Re: eppoh] #798071 03/19/07 05:07 PM
Jake97T Offline
you could but a screen on the elbow inside the fender welll to keep them out of the air filter box...hope you have an air filter in there otherwise you might have some mice making their home in the throttle body...
Re: On keeping mice out [Re: Tglow] #798072 03/19/07 05:53 PM
garym Offline
That canned expandable foam insulation works pretty good for sealing up the small cracks they get in through. I swear they must be able to "disjoint" their bodies from the little amount of space it takes for them to get into things.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6435 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-11-02 08:27:35 UTC
