90 sidekick oil pan removal
#798229
03/19/07 06:30 PM
is it possible to remove the oil pan without taking motor out? if it is, plz someone tell me how to do it. what a pain this is! <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 90 sidekick oil pan removal
[Re: suzuki_sweety]
#798230
03/23/07 05:57 AM
On my 94 4x4 tracker, I had to drop the front differential to remove the oil pan when I was replacing the gasket. Once the differential was out of the way, I had to drop the oil pan down, remove the pickup tube and then I could get the pan the rest of the way out.
Ridgecrest, CA 2000 Tracker 2-dr
[Re: suzuki_sweety]
#798231
03/29/07 01:03 AM
DesertTracker is right! Removing the front diff. is the easiest way to remove the oil pan. But I also recall needing to drop the steering linkage (tie-rods and pitman- arm) down off the frame and loosening both left and right side motor mount nuts to allow the engine to be lifted slightly to fully remove the oil pan.
[Re: caymin]
#798232
03/31/07 09:37 PM
Its all coming back to me now...I did have to loosen the motor mounts and lift the engine a couple of inches. I don't remember messing with the steering linkage. Maybe that would have made it easier had I done so, though.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5989 MB (Peak: 0.6538 MB) Data Comp: Off Server Time: 2026-06-21 19:04:58 UTCValid HTML 5 and Valid CSS
