90 sidekick oil pan removal #798229 03/19/07 06:30 PM
suzuki_sweety Offline OP
is it possible to remove the oil pan without taking motor out? if it is, plz someone tell me how to do it. what a pain this is! <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 90 sidekick oil pan removal [Re: suzuki_sweety] #798230 03/23/07 05:57 AM
DesertTracker Offline
On my 94 4x4 tracker, I had to drop the front differential to remove the oil pan when I was replacing the gasket. Once the differential was out of the way, I had to drop the oil pan down, remove the pickup tube and then I could get the pan the rest of the way out.
Ridgecrest, CA
2000 Tracker 2-dr
Re: 90 sidekick oil pan removal [Re: suzuki_sweety] #798231 03/29/07 01:03 AM
caymin Offline
DesertTracker is right! Removing the front diff. is the easiest way to remove the oil pan. But I also recall needing to drop the steering linkage (tie-rods and pitman- arm) down off the frame and loosening both left and right side motor mount nuts to allow the engine to be lifted slightly to fully remove the oil pan.
Re: 90 sidekick oil pan removal [Re: caymin] #798232 03/31/07 09:37 PM
Its all coming back to me now...I did have to loosen the motor mounts and lift the engine a couple of inches. I don't remember messing with the steering linkage. Maybe that would have made it easier had I done so, though.
Ridgecrest, CA
2000 Tracker 2-dr
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5993 MB (Peak: 0.6542 MB) Data Comp: Off Server Time: 2026-07-15 06:51:35 UTC
