Re: Any BC, Canada Mitsubishi owners out there?
[Re: AnthonyG]
#798258
03/19/07 11:40 PM
The 10W-30's a bit thin,especially if it's burning oil. How much do you go through? If it's less than a litre for every 4 tanks of gas, you may be ok. If it's a liter per tank, and there's a nasty dark cloud behind you, then not much gonna help that other than a rebuild. The heavier Castrol was the best I ever experienced in the 2.6L. And even a re-build will need to deal with the carb controls.
Check which carb you got, it is extrememly important. If it's the Mitsu carb (made by Mikuni), you have a chance... Any missing hoses and bits can probably be found from a wreckers in WA. But it's of no help if it's not the Mitsu carb.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
[Re: don]
#798259
03/19/07 11:54 PM
It is a Mikuni carb. I go through about a litre 1 month.so about every 4-5 tanks of gas. There really is no cloud of smoke behind me when i am driving it only smokes on initial startup and if i sit there and let it idle for a while. I am not sure but i think the guy may still have all the emission controls and stuff that he took off. It is just a matter of getting a hold of him and finding out where evrything goes
[Re: AnthonyG]
#798260
03/20/07 12:20 AM
I'll check out Captain Crunch's mods. In the meantime, I'll check out the torsion bar and figure out how to adjust it.....currently my truck is a little higher in the back, so lifting the front should level it out. I was about to buy one of the Hgihlift Jacks today, but then i realized that I really don't have any good jacking points that the jack would work on, with the exception of the bumper corners...which would more than likely be too soft, and would bend. the highlift jack won't reach underneath to the frame anywhere either..hmmmm, what to do? Perhaps i should bolt on some hitch mounts, front and back, get a portable winch, (which will fit either hitchmount), then i could also use the hitchmounts as front and back jacking points.
What do you figure I could get a set of those Gen II coilovers for in order to lift my truck a bit more in the rear? I would love to fit some 33's on there.
Coffee anytime would be great!
92 Mighty Max V6 4x4 SWB 32's, torsion lift, yota lift shackles in the back, rear LSD, 4.22's safari rack, 3" body lift
85 VW Westfalia Baja beast 1975 HONDA CB500T cafe racer Sector 9 pintail
[Re: AnthonyG]
#798261
03/20/07 01:11 AM
Now you're on the right track. With a bit of luck you might be ok!
There are full manuals in PDF format out there for your truck. I think they're on a Russian site, but the manuals are in English. They really help!
[Re: shorepig]
#798262
03/20/07 01:15 AM
Fight for Right to drive from Right! www.ivoac.caStay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
[Re: shorepig]
#798263
03/20/07 01:17 AM
Yeah, Lifting points do matter!
Check the archives (I think), there was a write-up somewhere on how to do the t-bars.
You might be able to get 33's in there without the Gen2 coils.
You're welcome to try swapping my 33x12.5's in to test. What you got on there now?
The Gen2 coils will have to come from the USA (I think), and you might be best off posting a request for help locating a set. I never needed them (I'm rear leaf), so don't remember who/when/what. If I remember, they'll gain you 2".
[Re: Pajerist]
#798264
03/20/07 01:18 AM
OMG, Another one! And a "real" Paj for a change! How's you rig for miles?
[Re: don]
#798265
03/20/07 01:27 AM
Oops! I was thinking of my volkswagen Westfalia! My Mighty Max Mitsu has leaf springs in the back ....so perhaps an add-a-leaf would be the best option for lifting the back. I currently have 31 x 10.5 Geolander A/T's on it. And they seemed to work pretty darn good yesterday in the mud.....and they are pretty much brand new (came with truck). But I would like to get some bigger meats to increase my clearance. I guess I should get set up with the proper recovery gear first, then start looking at performance improvement mods.
[Re: shorepig]
#798266
03/21/07 05:16 AM
Hey man try some 15w40 & fill the tank with chevron premium fuel,94 octane just before u get the air care done .Let use know how it goes.Peace. <img src="/forums/images/graemlins/cheers.gif" alt="" />
"YOU CAN ONLY LEARN SO MUCH KNOWLEDGE IN A LIFETIME..BUT IMAGINATION IS WHAT MAKES THE WORLD GO AROUND" 89 POWER RAM D50 4X4 XCab 2.6L 91 Grand Prix GTP 3.4L 87 Jeep YJ Laredo 4.0L EFI
