Mystery light in corner light assembly--99 Trooper #798458 03/20/07 02:46 AM
Tim_in_NC Offline OP
Does anyone know what all the bulbs do in the corner light assembly on a 99 Trooper? There is one light that I cannot get to turn on. Next to the headlight, there is an upper and lower light; the upper light is an amber bulb in a clear lens--this is the parking/running light. Below that is a clear bulb in a clear lens. What is this for? The turn signal is next to these two lights, and the fog lights are well below on the bottom of the bumper. I have tried every combination of lights/high,low beam/signals/with,without fog lights, etc., and this bulb will not turn on. There is a fuse in the fusebox called "cornering lights," and I'm not sure if this is related. Could the bulb be some sort of daytime running lamp option?
Re: Mystery light in corner light assembly--99 Trooper [Re: Tim_in_NC] #798459 03/20/07 03:14 AM
E
EricW Offline
The bulbs should burn when you have your headlights on and then use your turn signals.
1996 Trooper S 3.2 5sp OME919/ProComp ES9000
BFG Dueler A/T REVO 265/75R16 w/Snowflakes
1991 Trooper 2.6 5sp 33x12.5 BFG T/A
Re: Mystery light in corner light assembly--99 Trooper [Re: EricW] #798460 03/20/07 03:18 AM
ISueYou Offline
It sounds like cornering lights to me, that is the light that comes on when the headlights are on and you put on the turn signal. They are supposed to light up dark corners.
If it won't come on and you know the bulb is good the contacts may be a bit corroded. Also check the fuse with a tester if possible.
Jay <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: Mystery light in corner light assembly--99 Trooper [Re: ISueYou] #798461 03/20/07 04:08 AM
litnin Offline
One thing to note....
The turn signal lever has to be locked in to place before the lights will come on.
If you just pull up on the signal lever without locking
the lever, the lights won't come on.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Mystery light in corner light assembly--99 Trooper [Re: litnin] #798462 03/21/07 04:21 AM
Ahhhh, very nice.
I had one bulb out and I must have been checking that one when I did my earlier test, since I already knew the other bulb was good. Thanks for the help,
Tim_in_NC
PS...If anyone in NC is looking for an '86 Trooper, I have one listed on the "for sale" page.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6056 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-06-20 18:18:00 UTC
