Tach hookup ? #798732 03/20/07 10:39 AM
G
grub Offline OP
I borrowed my neighbors old school tach/dwell meter to set the RPM on my old 22R. it says to hook it to the negitive on the coil but I'm not real sure where that is, here's a pic of my coil, any help would be greatly appreciated !
The green connector on the lower left is empty, I tried hooking into that but it didn't seem to be it.
Re: Tach hookup ? [Re: grub] #798733 03/20/07 03:09 PM
maxxis85 Offline
On my 3.0 1989 toyota PU. i used the IG- teminal located near the engine diagmostics port by the fuse box under the hood on the passenger side.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: Tach hookup ? [Re: grub] #798734 03/20/07 06:19 PM
cktoy Offline
search for a thread on sr5 gauge cluster hook up under my name.it has a link of a pic that shows where to hook the tach. it is an empty green plug with one wire to it.I dont know how to post the link so you could klick it or I would
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Tach hookup ? [Re: grub] #798735 03/20/07 06:50 PM
stock87 Offline
Try that green one again, it should be it. Crimp a spade terminal on a short length of wire and jam it in to make sure there's good contact.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Tach hookup ? [Re: stock87] #798736 03/21/07 02:35 AM
Z
zachtheterrible Offline
Yes, you definitely hook up to the small green connector, it can be kinda tricky hooking up to that. The other wire of the tachometer just hook up to the negative battery terminal
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Tach hookup ? [Re: maxxis85] #798737 03/21/07 05:59 AM
IceBlueT Offline
I agree with him. i put an auto-meter sport comp in my truck, and i used the tach hookup next to the diagnostic port on the passenger side of the truck. it looks like an older truck, so im not sure if it would have it. my friends 85 4runner is missing it, along with the diagnostic port.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Tach hookup ? [Re: IceBlueT] #798738 03/21/07 04:57 PM
stock87 Offline
That looks like an external voltage regulator in the pic, so he's probably got an 84 or older, which doesn't have the diagnostic port, just the check connector in green.
Re: Tach hookup ? [Re: stock87] #798739 03/22/07 06:09 AM
G
grub Offline OP
Thanks for all your help everyone, my truck is an 80 and probably doesn't have the diognostic port, turns out the empty green connector with the black wire is the one I needed, last night I checked the batteries in the tester and one was dead, fresh batteries seems to have done the trick.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6244 MB (Peak: 0.7227 MB) Data Comp: Off Server Time: 2026-06-07 06:57:40 UTC
