turn signal problem? #798779 03/20/07 04:32 PM
raiderquest Offline OP
My turn signals would not stay working at idle but once I increased the idle speed, the signals will stay working.Is this normal or does this mean the alternator is not working up to capacity?
Re: turn signal problem? [Re: raiderquest] #798780 03/21/07 03:03 AM
Pajerist Offline
this is definitely bad <img src="/forums/images/graemlins/scared.gif" alt="" />
Fight for Right to drive from Right!
www.ivoac.ca
Stay away from Nic's Garage at 120 West 1st Ave in Vancouver BC!!!
Re: turn signal problem? [Re: Pajerist] #798781 03/21/07 04:26 AM
89montero Offline
it's the alternator. Mine did this too. They had been acting up for about a year getting worse and worse. I bought a new electronic flasher which helped but then one day the alternator just completely gave out. Got a new one and everything's back to normal!
1989 Montero 4dr V6 3.0l
Re: turn signal problem? [Re: Pajerist] #798782 03/21/07 04:28 AM
StockRaider Offline
No its not bad, replace the relay and all shall be well.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: turn signal problem? [Re: StockRaider] #798783 03/21/07 04:37 AM
CapnCrunch Offline
A relay would be cheaper to swap out, but it doesn't sound like the relay to me. In my experience, relays tend to just fail.
I'd have to agree that it sounds more like the alternator. What you can do is take it out and take it to someplace like Advance Auto and have them bench test it. Places like that will bench-test alternators for free in just a few minutes.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: turn signal problem? [Re: CapnCrunch] #798784 03/21/07 07:45 PM
DirtyOldTown Offline
Mine did the exact same thing - bad alternator. I rebuilt it and it's been fine since. The wipers would go really slow too - you may want to look at those as well.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: turn signal problem? [Re: raiderquest] #798785 03/22/07 03:18 PM
yes, the wipers are slow, in fact, the fast speed isn't working. I have several alternators to get checked.Is there a difference in amps between a raider alternator or a conquest alternator? I am glad I have not put the AC compressor on yet.
Re: turn signal problem? [Re: raiderquest] #798786 03/22/07 05:08 PM
Trail_Maker Offline
Well, my alternator works fine, and my blinkers have been doing this for I know of at least 6.5 years since I have had it! My dad gave it to me back in Nov.2000 I have put about 20k on it in 6.5 years and the blinkers kinda blink slow and sometimes will get stuck but not every time...Well, I need to fix it, but its one of those thinks that you never think of until it does it again! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1990 LWB 3.0L With 33/12.50's K&N 251k Miles
Re: turn signal problem? [Re: raiderquest] #798787 03/23/07 02:56 AM
I'm not sure if there is a difference in the two alternators or not. Mine would also crank a little slow sometimes. The voltage regulator died a slow death, so it was intermittant for a while. You may even try hooking it up to a battery charger and see if your signals speed up. Also, if you've got a meter, measure the voltage at the battery while @ idle. Should be in the 13-14V range (has to be over 12.6 v).
Re: turn signal problem? [Re: raiderquest] #798788 03/23/07 05:55 AM
The Conquest alt. is a higher output unit. Use one of those.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6372 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-11-02 15:04:42 UTC
