Re: '89 montero is it worth fixing? [Re: JacknCoke] #798868 03/21/07 03:30 PM
Dan1171 Offline
I'm asking $500 for the engine. That doesn't include the manifolds or distributer. Basically just the engine. It has had a new crank, bearings, and lifters installed. It is driveable right now. I haven't sold anything off of it yet.
Re: '89 montero is it worth fixing? [Re: Dan1171] #798869 03/21/07 06:18 PM
JacknCoke Offline
I'd like more details if possible. Is there a good way to contact you?
Re: '89 montero is it worth fixing? [Re: CapnCrunch] #798870 03/21/07 06:23 PM
X
xcanuck Offline OP
Thanks for the responses, I didn't think they would come so quick..it's a 4 door, does that mean LWB?. I'm in SoCal, home of the expensive mechanic...but it looks as though $1350.00 will get a new engine installed. Still worth it?
'89 LWB 3.0 5spd bouncy seat 31" no lift yet....
Re: '89 montero is it worth fixing? [Re: JacknCoke] #798871 03/21/07 06:46 PM
Dan1171 Offline
PM me and I will give you contact info.
Re: '89 montero is it worth fixing? [Re: xcanuck] #798872 03/21/07 07:43 PM
DirtyOldTown Offline
I got mine in the exact same situation - turned out to be a blown head gasket. Wasn't too tough to fix but once I got it running everything else started to break. I love driving it but I doubt it will ever stop nickle-and-diming me. In my situation (with a full shop at my disposal) it's easy to drive it daily. If you aren't going to be doing any of the work yourself things will get expensive.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: '89 montero is it worth fixing? [Re: xcanuck] #798873 03/21/07 07:53 PM
Yup, this is likely the most active mitsu 4x4 forum in N. America and possibly the world. Welcome.
Yes it does. LWB means long wheel base.
$1350 only? Definitely. What kind of warranty will they give with that install. Is it a used engine or also rebuilt? In N. Cal, it cost 1800+ for an upper end rebuild.
Re: '89 montero is it worth fixing? [Re: off-roader] #798874 03/21/07 08:08 PM
sparkem Offline
Sounds too cheap, what kind of engine?
Re: '89 montero is it worth fixing? [Re: off-roader] #798875 03/21/07 09:29 PM
X
xcanuck Offline OP
The engine is $750, block and head w/ 6 mos. warranty, at C&T in Ontario,CA ....not sure if engine is rebuild or used, installer wants $600. no mention of his guarantee. I'm having a friend look at it tonight to try and figure if it's just the head gasket before i commit to the engine swap..
Re: '89 montero is it worth fixing? [Re: xcanuck] #798876 03/21/07 11:20 PM
Get a compression tester with a quick connect hose, like an air hose quick connect. Remove the plugs. Screw the comp. tester hose into a plug hole. Apply compressor air, at about 40psi. Caution, the crank may rotate as the air forces the piston down. have the radiator cap open, and listen for air and look for bubbles in the radiator neck. There will also be leakage into the crankcase past the ring gaps. Have the oil fill cap off and listen for one cylinder that leaks worse (bad rings).
Any engine clatter, knocking or tapping when it runs?
Re: '89 montero is it worth fixing? [Re: fasteddy] #798877 03/22/07 05:37 PM
X
xcanuck Offline OP
Thanks for the help. There doesn't seem to be any clatter, or noise, in fact it sounds great..but I'll try the leak test you suggest and take a look...
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7622 MB) Data Comp: Off Server Time: 2026-06-07 05:51:45 UTC
