Question about gear parts?? #798983 03/21/07 05:47 AM
W
W69DY Offline OP
So im only getting like 9 MPG on my yota. Anybody have any ideas why. i just changed the plugs and wires. I think its my gearing to be honest. I have stock gears in with 33x12.5x15 BFG. I wonder if this kit off ebay would fit everything. http://cgi.ebay.com/ebaymotors/4cyl...itemZ160098193916QQrdZ1QQsspagenameZWDVW
Also how hard is it to change the gears out. Im not the best with the tools but not the worst either. If i cant do it how much should it cost to pay somebody to do it, with or without the parts. Thanks guys all help would be grateful. WOODY
Oh my truck is a v6 automatic
94 Yota, ext cab, V6, 4x4, 4in pro comp lift, 3in body, 33" BFG A/T
Re: Question about gear parts?? [Re: W69DY] #798984 03/21/07 06:21 AM
Z
zachtheterrible Offline
You should definitely be getting better mileage than that, I have 33's and just went from stock 4.10 gearing to 4.88 gearing because I"m gonna be putting 35's on it next tire set. Anyway, I was getting 15-17mpg in the city. Mine's an '84.
As for the gears, ask what kind of gears they are. I got yukon gears, the best as far as I know. Don't go cheap on this. Find out if you have an 8" diff, I would imagine that you do, but just make sure.
The install is probably one of the more complicated things I've ever done, I had to order two specialized tools which I got off ebay for $125, an inch pound torque wrench and a dial caliper. Believe me, it's no simple process, but it can be done with lots of patience and a full toolset.
http://www.pirate4x4.com/articles/tech/billavista/Gear_Setup
Not your exact diff setup, but it'll give you a great idea of what's involved.
http://www.gearinstalls.com/
Very very helpful
No idea how much it is for a shop to do it.
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: Question about gear parts?? [Re: zachtheterrible] #798985 03/21/07 06:41 AM
W
W69DY Offline OP
so with my set up should i go with 4.88 or 5.29. The yukon gears you speak of are the chevy yukon gears or is YUKON the name brand.
What can i do about my gas milage???????
thanks WOODY
Re: Question about gear parts?? [Re: W69DY] #798986 03/21/07 03:06 PM
Staceman Offline
Better not buy the Ebay kit. Looking like Genuine brand gearset with the ring gear bolts included. I am going to guess you have 4.56 gears. 4.88 will help. That's what came with you truck IF it was stock with 31 x 1050 tires. (gear code G144, V6, Auto) 5.29 will probably be better for you. You can purchase used 4.88 diffs from car-part.com for a more reasonable price though, then just plug-n-play the entire diff. Your call. Also, check codes to see if your O2 sensor is defective. This will also cause bad fuel mileage.
Re: Question about gear parts?? [Re: Staceman] #798987 03/22/07 11:12 AM
W
W69DY Offline OP
HOW do u check the code... thanks WOODY
Re: Question about gear parts?? [Re: W69DY] #798988 03/22/07 12:17 PM
drainsbe Offline
codes
Dave
86 4Runner, 22R-EB
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6093 MB (Peak: 0.6804 MB) Data Comp: Off Server Time: 2026-06-10 01:56:43 UTC
