Timing Chain Cover #799048 03/21/07 10:25 AM
casper3t Offline OP
When I did my timing chain a couple of months ago I broke a piece off the cover. I don't have a picture of the actual cover but I got a picture of a cover and circled in yellow in the picture where it broke.
I was low in money and that was the second cover after the first one was eaten up by the chain after it broke...
So I was wondering if that little broke off would it effect my oil pressure or harm my engine. I don't have a oil pressure gauge to measure it but the truck seems to run fine. I know I have to change it sooner or later, I'm just hoping it would be later.
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
Re: Timing Chain Cover [Re: casper3t] #799049 03/21/07 03:10 PM
Staceman Offline
Not to worry. Has nothing to do with oiling. Just more of a guide for the timing chain. Probably to lessen the damage if a chain fails. But, there are bigger problems than that if it broke. I'd run it as is and rest easy. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Timing Chain Cover [Re: casper3t] #799050 03/21/07 05:33 PM
MAC Offline
one of mine broke a piece at the same location. smoothed down the ragged area and re-used it. never had a problem.
Re: Timing Chain Cover [Re: casper3t] #799051 03/21/07 11:37 PM
matts Offline
I'm running one like that right now too. In fact all the tab material is missing on mine. I think the main thing that shelf does is to keep the chain from falling off the crank sprocket while you are installing it. I fumbled the cam gear while I was installing the cam with the result that my chain came off the crank sprocket. I had to pull the timing cover back off to be able to see that the reference mark on the crank sprocket was still aligned with the reference link on the chain. -- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6032 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-06-07 11:37:31 UTC
