Replacing my 2.5L #799067 03/21/07 03:08 PM
RalkClimber Offline OP
Thought I would share photo's of the 2.5L replacement. Just got the new(reman) engine yesterday. It looks great. I'm still cleaning and painting parts before I install the new motor. I'll keep sharing smile
http://i166.photobucket.com/albums/u97/ralkclimber/P3200036.jpg
http://i166.photobucket.com/albums/u97/ralkclimber/P3200037.jpg
http://i166.photobucket.com/albums/u97/ralkclimber/P3200033.jpg
Ralk
'97 Jeep Wrangler 2.5L 105k Miles
Recent Replacements: Cam Shaft, Lifters, Push Rods, Distributor, Dist. Cap/button, Plugs, Oil Pump, Oil Sending Unit, Timing Chain/sprokets, and all associated gaskets.
Re: Replacing my 2.5L [Re: RalkClimber] #799068 03/21/07 09:46 PM
9
93yj Offline
Ralk, reminded me of the 2.5 I just replaced in mine. Pretty easy job. I got 144,000 out of the first, so we'll see how this one does. I notice a slight power increase, but nothing awe-inspiring. 2.5's are what they are!!!
Oh, by the way, how was/is the idle on you're 2.5? I cannot get this thing to idle smooth or like I want it to idle. The old motor was the same way. Maybe it's inherent to a 2.5. My tachometer is steady as can be but the vibration is still there.
Re: Replacing my 2.5L [Re: 93yj] #799069 03/21/07 09:55 PM
Well the old one had the same vibration your speaking of. Hoping this one is a little smoother. I'll let ya know.
Ralk
Re: Replacing my 2.5L [Re: RalkClimber] #799070 03/27/07 02:56 PM
Finished the 2.5L swap this past saturday. No pics yet.. I was way to tired smile I didn't take the trany out with the motor and had a hell of a time trying to line up the new clutch. I finally found a store with an alignment tool and it went in real easy after that.
Anyways.. It is running great. No hesitation, no vibration, no backfires... BTW - I think some of my vibrations was coming from my clutch bearing. I might be wrong, but that baby was shot...
Oh ya.. It started first crank!! I was shocked beyond belief.
I have better low-end torque, but not high-end speed. I expect to get better high-end once the engine breaks in.
Question: I almost picked up a throttle body spacer this weekend as well, but thought I would ask everyones opinion on it first.. <img src="/forums/images/graemlins/confused.gif" alt="" />
Ralk
Re: Replacing my 2.5L [Re: RalkClimber] #799071 03/27/07 03:10 PM
BobRowe Offline
Save your money and don't get the tbs.
Re: Replacing my 2.5L [Re: BobRowe] #799072 03/27/07 04:11 PM
BigJim Offline
Drive around a bit with that new engine. If you see a dead dog beside the road get out and stuff some money up under his tail.. Then see if your engine runs any better. Purchasing a TBS is about the same as stuffing the money under a dead dogs tail! It does absolutly NOTHING to your engine.
Re: Replacing my 2.5L [Re: BigJim] #799073 03/27/07 05:43 PM
Love the analogies... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Ralk
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6109 MB (Peak: 0.7049 MB) Data Comp: Off Server Time: 2026-11-01 11:35:57 UTC
