NP231 output shaft seal...
#799140
03/22/07 01:55 AM
I've replaced mine twice in about 60,000 miles and it looks like it may need to be replaced again. Is this normal? It seems as though there is ALWAYS a bit of spray on the underside of the body. I never get a puddle under the Heep, but the fact that it is always a LITTLE oily back there always has me checking it out. I don't wanna run out of fluid! I can certainly understand a minute amount of fluid since that seal is the only thing holding back all of that +4...plus, it's obviously not 100% leakproof since the slip yoke is constantly spinning inside of it.
Re: NP231 output shaft seal...
[Re: 93yj]
#799141
03/22/07 02:32 AM
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
[Re: 93yj]
#799142
03/22/07 01:34 PM
i've done mine a few times. first because i thought it was leaking, but it there was actually a crack in the cone. then again because mt transmission mount was shot and under hard accelleration things would move(hense broken cone). just something to check
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5890 MB (Peak: 0.6417 MB) Data Comp: Off Server Time: 2026-07-13 06:10:38 UTCValid HTML 5 and Valid CSS
