Detroit locker disassembly #799210 03/22/07 04:38 AM
bodo Offline OP
I blew my 4.88 (sheared 5 pinion teeth) third this past weekend and had to limp it about 15 miles at 20mph. I would like to take my detroit apart and clean the metal out if there is any. If someone has some pics, links, or tips it would really help.
Re: Detroit locker disassembly [Re: bodo] #799211 03/22/07 08:39 PM
E
Eck Offline
There is really not much to it. Pull the 2 axle shafts out a bit, disconnect the driveshaft from the yoke on the rear end and take out the whole unit. Leave everything together on the ring and pinion side so you don't have to adjust anything. Maybe use a magnet to tickle out the big chunks and flush the rest.
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: Detroit locker disassembly [Re: Eck] #799212 03/23/07 10:15 AM
O
ovrrdrive Offline
Zuk took one apart but offhand I couldn't see which link it was. Look around you'll find it.
http://www.gearinstalls.com/
Re: Detroit locker disassembly [Re: Eck] #799213 03/23/07 02:16 PM
bodo Offline OP
I know how to pull a third and get the locker out, what I want to do is take the actual locker apart.
Re: Detroit locker disassembly [Re: ovrrdrive] #799214 03/23/07 02:35 PM
grandeyota Offline
He has some good pics in this link of the one he did for me:
Zuk
Fur clog in the sausage grinder
Re: Detroit locker disassembly [Re: ovrrdrive] #799215 03/23/07 02:36 PM
bodo Offline OP
Thanks for the response. I've spent hours on that site and I knew I had seen a writeup but couldn't find it.
I did get the link to Zuk's writeup from a guy on the pirate board but there wasn't any torque specs when he put it back together. I'll probably email him and just ask.
Re: Detroit locker disassembly [Re: grandeyota] #799216 03/23/07 02:54 PM
bodo Offline OP
Zuk
Thanks that's the link I got from the guy on pirate, between that one and the other autopsy one I should be fine.
I'll be glad when my gears get here because I'm riding around on a stock geared third that's welded with 36s and I hate it.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6128 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-11-02 23:30:44 UTC
