My rusty nuts. With pictures! #799318 03/23/07 01:00 AM
RichO Offline OP
02 sensor mounting flange pics
I took some shots of my 02 sensors. The above picture shows the condition of both of them. It looks as if the studs are pretty clean. A different alloy or hardness maybe? Does anyone think I have a shot at grinding down what's left of the nuts, then peeling away what's left of them from the studs? I've done this before on body panels where the bolts have busted off. I was able to get well centered with a punch and drill the bolt out, then I pulled out what remained. It looked like a helicoil. I'm guessing this might be different because of the heat on the parts. Totally bonded together by rust? If that's the case, is there a part # for a replacement flange, and should I be prepared to have new one's welded on at an exhaust shop? Has anyone had to have this done?
TIA!
Rich
'86 4 X 4 Hilux (sold)
'97 T-100 4 X 4 SR5
'05 Tacoma 4 X 4 TRD Sport DBL Cab LB
Re: My rusty nuts. With pictures! [Re: RichO] #799319 03/23/07 01:24 AM
Jake97T Offline
I had one of my studs shear off. I ground the flange off and made a new one, welded some bolts through the back side and then onto the exhaust pipe, as far as replacements go i had a hard time finding one, never did. an exhaust shop would probably have access to one,
you could probably tap the holes and get thread in some new studs.
Re: My rusty nuts. With pictures! [Re: RichO] #799320 03/23/07 01:24 AM
CJMT100 Offline
Penetrating oil and a socket smacked on over that. I took some off my old camry that were like that, penetrating oil worked and the rust came off when I smacked a ratchet on.
That dont work try heat
Re: My rusty nuts. With pictures! [Re: RichO] #799321 03/23/07 02:36 AM
surlynkid Offline
pb blaster every day for a few days. they will come off. the threads on the studs will be fine. as said, maybe find a socket one size smaller (even convert back to SAE), pound it on and then take it off.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: My rusty nuts. With pictures! [Re: surlynkid] #799322 03/23/07 03:54 AM
garym Offline
I swear by this stuff. I tried everything to free up the heat valve in the exhaust manifold in a 1972 Hornet. PB blaster, WD40, Triflo, Liquid Wrench, etc. The next day after using this stuff it freed up. It is not cheap but sure works.
Kroil
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: My rusty nuts. With pictures! [Re: garym] #799323 03/23/07 06:57 AM
adam Offline
That's all I use. I lost my faith in all the others years ago. It's worth every extra penny per drop.
~Adam
Re: My rusty nuts. With pictures! [Re: adam] #799324 03/23/07 07:08 AM
kewlynx Offline
x 3. Jackovich Industrial Hardware carries it here in FAI. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: My rusty nuts. With pictures! [Re: adam] #799325 03/23/07 08:28 AM
BamZipPow Offline
They even have a free offer... I just signed up with my CC and didn't order anything...I'll see if it's really a free offer. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: My rusty nuts. With pictures! [Re: RichO] #799326 03/26/07 08:21 AM
W
Winkel1 Offline
Just changed my O2 sensor last night. My nuts weren't quite that bad, but they were bad. I shot them with WD40 and they came loose a lot easier than I thought they would. I had more trouble getting the damned clip undone. You might even be able to get them to move with a pair of Channellocks. The studs should be stainless steel.
Winkel
98 T100 SR5 4WD
Rhino Liner
Warn Hubs
Mostly Stock
Re: My rusty nuts. With pictures! [Re: Winkel1] #799327 03/31/07 05:00 AM
RichO Offline OP
Well, after PB Blasting for a week I climbed under to have a look. I ended up using a really mini vise grip and gripped the nuts by the base. Not too much pressure, and they all came off! What was strange was that the threads inside those wildly rusted nuts were perfect. No shyte. The threads on each stud were perfect too. I had a die but there wasn't a case to use it. I gotta say, it was nice not being half phucked this time. Well, there's always next time. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'97 T-100 4 X 4 SR5
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6398 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-06-07 10:35:55 UTC
