spare parts on trail? #799422 03/23/07 05:49 AM
W
wheeler2006 Offline OP
I own a 96 rodeo and I have been off-roading with it for about a year or two and I think it is about time to find out from people that drive similar cars,
what spare parts should I carry with me on the trail.
Can you guys tell me what is most likely to brake?
I want to be prepared as much as I can.I have an extra set of tie rods but that is about it./other than tools/.I have a 3" calmini suspension lift and a factory 2 piece rear drive shaft and it is not vibrating at all.Do you guys think that should be potential hazard? Should I have a spare one or get a one piece?
tx for the help.
Re: spare parts on trail? [Re: wheeler2006] #799423 03/23/07 11:18 AM
strawmyers Offline
Isuzu Moderator
I'd get a one-piecer as its only a matter of time before your carrier bearing eats itself. As for trail spares, definitely a tie rod or two. Those are probably the #1 most prone to breakage thing on a wheeled 'Zu; and you can't get back home without them. The DOR tie rod shieldz or Independent4x beefy tie rods are a nice upgrade; but I'd still keep one spare around 'just in case'. As I said, you are going anywhere if one of those breaks. Other things like CV's can be replaced back at home.
Sean Strawmyer
Re: spare parts on trail? [Re: strawmyers] #799424 03/23/07 02:55 PM
Jim_Paget Offline
I also carry spare belt(s). My engine uses a serpentine belt, so if it goes everything is gone.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: spare parts on trail? [Re: wheeler2006] #799425 03/23/07 03:34 PM
TrailMystic Offline
By far, the piece of equipment I use the most on the trail is my chain saw. I tree over a trail can end a trip quickly. I carry a spare cv axle on longer trips like Uwharrie which last 3 or 4 days. Twice a broken CV axle shortened a multiple day trip. No problem getting home, but it disappointing not to be able to wheel the last day or two. I picked up a used OEM CV axle in great condition for $60 at a salvage yard. I hate the remanufactured ones. They sometimes bind, have cheap boots, and are not as durable.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: spare parts on trail? [Re: TrailMystic] #799426 03/23/07 04:19 PM
Smiley Offline
If you're planning on driving through any mud, you might want to have a spare alternator on-hand (or at the very least, be ready to make a trip to the local auto parts store... in someone else's passenger seat <img src="/forums/images/graemlins/wink.gif" alt="" /> )
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: spare parts on trail? [Re: wheeler2006] #799427 03/23/07 05:36 PM
Bansil Offline
Make sure you have large washers installed on the bolts that screw into the upper control arm "fulcrum pin" so the poly bushings don't "walk"out.
Other than a few fuses and maybe a spare relay,think about a fire ext.
The 'zu's are pretty tough.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: spare parts on trail? [Re: Bansil] #799428 03/23/07 05:41 PM
A
anubis Offline
I carry an old belt, wont go anywhere without one. Also, extinguisher, spare CV, and all your lubes. I would make gearand enigne oil a priority.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
Re: spare parts on trail? [Re: anubis] #799429 03/24/07 04:20 PM
muskyamigo Offline
The best thing to bring is a group of experienced wheelers/wrenchers with similiar vehicles as yours (Isuzus).
But regardless a basic list would include:
Spare tire, and items needed to change it.
3qts engine oil and filter.
tierod and tools to swap it.
belts(s)
maybe a spare hub or drive flange
Tools (probably a few things missing here)
8, 10, 12, 14, 17, 19, 22mm wrenches and socket (w/ratchet and extensions)
screwdrivers
wirestripper/cutter
couple types of pliers
2-3 lb hammer
misc wire, connectors and fuses
JB weld
Duct tape
WD-40 (or similiar)
funnel
TP
You don't need to bring every imaginable spare part and tool on the trail. It adds unneeded weight, and really there is a limited amount you can (or will) fix on the trail anyway. You need the tools for the parts and things you can easily fix. Or to rig something to get you off the trail so you can hitch a ride in to town for parts.
Generally with use, you'll get a feeling for what tends to fail on your vehicle and carry the parts and tools for the items that will leave you stranded. Like tierods or the poorly placed oil filter on my 98.
-Mike
Mike Walter
'98 Amigo well used
'94 Rodeo in need of help
'99 Ram CTD for hauling feather pillows
'01 unheated shop
Re: spare parts on trail? [Re: muskyamigo] #799430 03/27/07 05:08 PM
N
NotSoSimple Offline
I am the king of too much junk:
2 Spare CVs
2 Spare Tie Rods
Spare Belts
Spare Cap+Rotor
Spare Slave Cylinder
Tranny/Brake fluid/Water/Oil
Tools to fix said parts
Chemtool/Goop/PB Blaster/Etc
Spare Relays, wire, soldering iron, crimpers/ends, fuses
Spare headlight bulb
I had a parts truck so I took ALOT of stuff for spares. Havnt broke anything on the trail eaither, just took a tire off the bead. Oh the list dosnt include recovery/rescue/survival gear.
'90 Trooper - 2.6L 5-Speed - 1" BL - Custom Roof Rack+2x55watt ProComp - Herculined Interior - Pace Setter Header - Dynomax Super Turbo - K&N - ProComp ES3000 Shocks - Optima Red - MSD 6A - 31" Kumho Mudders - Black Rock Crawlers
Re: spare parts on trail? [Re: NotSoSimple] #799431 03/31/07 09:51 PM
Paddler Offline
1. Spare Tie Rods- the most breakable item on your rig.
2. CV Shafts - If you break it, you'll get off the trail, but you week is done if you don't have a spare.
3. 14 mm washers for when your shims fall out. Plenty of folks who have the blue UCA's have issues keeping them in there. While your at it, back the pivot bolts up with another nut on the backside and run a zip tie through the shims you currently have so when they do eventually fall out, they will not go anywhere.
4. Center pins for the rear leaf springs, seen those snap about a dozen times now. You'll want to bring a few C-Clamps as well to help getting them back together.
5. A drain plug that expands. Seen three oil pan plugs get ripped out.
6. one set of spare belts
7. One extra used wiper blade.
8. I wouldn't worry about the alternator......192,000 miles and still going on the original, as well as the original starter and coil pack. O' I'm in mud, sand, and water alot as well.
9. One spare transmission if you have a 4L30..........wait a minute, better make it two or three.
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6412 MB (Peak: 0.7666 MB) Data Comp: Off Server Time: 2026-06-10 07:25:16 UTC
