Welding....
#799508
03/23/07 04:10 PM
Just a quick question- where in the world can i disconect my computer from the ground so that i don't fry it when i start welding on my frame... any ideas?
trav
1998 Isuzu Rodeo -- slightly modified.
Re: Welding....
[Re: trav]
#799509
03/23/07 04:13 PM
Most people disconnect it on the neg terminal. That's all I've ever done. I've never cooked a computer.
Joe
Re: Welding....
[Re: Bigpoppax2]
#799510
03/23/07 04:56 PM
Trav -
post up on Trailseeker and tell us what you are doing!!!
Jeff
(oh, and for post continuity, I agree with the statement above...)
Jeff Mason
Whatever makes you upset in someone else...also exists in you
Re: Welding....
[Re: Jeff Mason]
#799511
03/23/07 11:23 PM
Isuzu Moderator
FWIW, I've never unplug anything when welding to my frame and have had no issues. Not saying you should do the same, just giving my experience.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
Re: Welding....
[Re: trav]
#799512
03/24/07 12:04 AM
As long as you aren't welding on the front end and clamping the ground on the rear end.. it shouldn't hurt the computer. Keep the ground clamp as close to your welding point as you possibly can.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake 1989 Trooper 2.6 auto 1989 I-Mark RS DOHC 1.6 1991 Stylus XS DOHC 1.8
Re: Welding....
[Re: litnin]
#799513
03/24/07 12:58 AM
ALLSO NEVER EVER HOOK THE GROUND CLAMP TO THE ENG OR THE TRANS, EX,OR THE DRIVE LINE , AS STATED BEFORE WHERE EVER YOU ARE WELDING ON THE FRAME OR SOME OTHER PART MAKE CERTAIN THE GROUND CLAMP IS ON THE SAME PART THAT YOU ARE WELDING ON AS CLOSE TO THE WELD CONTACT AS YOU CAN GET, AND YOU SHOULD NOT HAVE A PROB, AS SOME MAKES OF THE ECM ARE VERY HARD TO GET TO ,IN ORDER TO DISCONNECT, JERRY
Re: Welding....
[Re: JLEMOND]
#799514
03/24/07 05:32 AM
thanks guys! i apreciate it! I just wanted to be sure i wasn't going to fry anything when i start with the welding.
