Anyone know the. . . #799515 03/23/07 04:17 PM
Kiacrawler Offline OP
Does anyone know the formula for finding out your MPG with 31" tires? I havent had my spedometer adjusted yet so my odometer counts slow. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Yup it's a Kia. 4" RockSportGear lift. 31 X 10.5 tires.
www.myspace.com/kiacrawler
Re: Anyone know the. . . [Re: Kiacrawler] #799516 03/23/07 05:03 PM
Hydra747 Offline
How have you been my friend???
Fill up your tank, set the trip odometer, burn your gas...Then get the total miles travelled on that tank of gas
NEXT---Fill up tank and see how many Gals. it took to fill up ----then divide the two which should = your mile to gallon!
I average 18-20 miles per gallon ( I know that sucks but nuke had the same problem) still wondering why????
Hope this Helps!!!!
Mike <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Anyone know the. . . [Re: Kiacrawler] #799517 03/23/07 06:19 PM
Lou Offline
...and then after that, knowing the measured diameter of original tires (let's say 28 inches), multiply the result obtained above by 31/28. (since the car will have been driven more actual miles than indicated because the larger size tires will rotate a lesser number of turns for travelling same distance).
Re: Anyone know the. . . [Re: Lou] #799518 03/23/07 07:49 PM
ok so after doing the normal equation, I multiplied the number by 1.14285 (which is 32 divided by 28) I got 21.17 miles to the gallon. Is this similar to what your guys are getting? <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Anyone know the. . . [Re: Kiacrawler] #799519 03/23/07 08:34 PM
Everet Offline
@ 60 mph average with stock 205's I'm getting between 24-25 mpg. My car is very sensitive to increased speed. If I'm doing 70 mph I only get about 22 mpg.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Anyone know the. . . [Re: Kiacrawler] #799520 03/23/07 11:47 PM
DennisThompson Offline
I've clocked mine with a GPS and I know I'm 16% off. At 50 I'm doing 58 so that means every 100 miles on the o-meter I'm going 116 miles. All Kais' came with 205s which are 27.1 inches tall (205 / .75 x 24.5 x 2 + 15 = 27.1). 25.4 converts mm to inches. Your should be the same as mine.
Hope that helps, Dennis
Re: Anyone know the. . . [Re: DennisThompson] #799521 03/24/07 12:07 AM
I just noticed I did the formula wrong. I did 32/28, which is ok cause the old tires were 27" and my now one's are 31". It had the same result. give or take a half mile or so. he he. I'm still interested on wht everyones gas milage is. I have one of the few SOHC engines which I hate for hills but it still runs well and gets decient MPG. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Anyone know the. . . [Re: Kiacrawler] #799522 03/24/07 03:50 AM
Lennyburger Offline
Spot on with Everet, @60mph, about 25mpg [ it's hard to convert Litres/kilometre ], with standard tyres, DOHC. That's with a tailwind going downhill of course <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
KIA, More dirt for ya dollar! 99 Sportage, Pod filter, Bosch Super4 plugs, electric thermo fan, racing pedals, Narva 100W driving lights, Yokhama 235/75R15 Super Diggers....getting to the rest bit by bit.
Re: Anyone know the. . . [Re: Lennyburger] #799523 03/25/07 06:58 AM
dirtcrazy Offline
I'm getting on average 24 with 215/75 15 all terrains.
Got torque?
'02 Ford F-350 STD Cab V10 6sp 4x4
12MPG in town and 15-17 on the highway.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6278 MB (Peak: 0.7317 MB) Data Comp: Off Server Time: 2026-05-29 19:58:23 UTC
