1988 5 speed 4Runner does not like to cold start #799665 03/24/07 03:56 AM
W
wreckhog Offline OP
Bought used recently. Previous owner had a brand new battery in it. Does not always start on a cold start. Some combination of waiting, turning the key and praying eventually starts it. On a warm start, it starts instantly every time.
It is a 5 speed and I have to depress the clutch to start it. When it doesn't start, it seems exactly as if the clutch is not depressed (though it is). The e-brake cable is broken BTW.
Is it likely something to do with the clutch cancel function? Is there a way to bypass that so I can troubleshoot further?
Whatr search terms would help me to look up similar issues in past threads?
Re: 1988 5 speed 4Runner does not like to cold start [Re: wreckhog] #799666 03/24/07 04:05 AM
rustylux Offline
Sounds a bit like your contacts are stuffed in the starter motor. Have a look at this link and see if that helps any <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 1988 5 speed 4Runner does not like to cold start [Re: wreckhog] #799667 03/24/07 08:11 AM
kewlynx Offline
You have a few possibilities here:
Starter contacts
Clutch out of adjustment
Fuel pressure issue
Check dem dere cable connections and make sure all is good to go; clean/dry/serviceable.
If the truck doesn't like to start at its first crank of the day, then cranks fine for the rest of the day, your fuel pressure might be bleeding off; usually the CS or fuel injectors or both.
22RE or 3.0?
The clutch cancel switch bypasses the pedal switch to start in neutral, meant for hill starts. The pedal switch might be out of adjustment; also check your free play and travel before chasing other stuff.
Clutch Maintenance
We have a 93 FSM sticky'd here that'll get you in the ballpark too.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5939 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-23 00:47:19 UTC
