22re valve cover baffle removal #799700 03/24/07 01:41 PM
Bolosh Offline OP
I'm in the middle of rebuilding my 22re (89 4x4). I decided to also remove the baffle from the underside of the valve cover to clean it out and also thought about powder coating the cover, which the baffle would have to be removed for anyway.
The baffle is factory installed with pressed in rivets... has anyone removed one before? Do you just drill out the rivets then tap the holes and bolt the baffle back on afterward? I'm interested in hearing about anyone's experiences with this.
Thanks!
Re: 22re valve cover baffle removal [Re: Bolosh] #799701 03/25/07 02:39 PM
Bolosh Offline OP
Nobody has done this?
Re: 22re valve cover baffle removal [Re: Bolosh] #799702 03/25/07 04:56 PM
87Toy4x4 Offline
i don't think anybody removes the baffle when they clean/paint there's. i didn't. and i'm almost positive you're only supposed to powder coat the outside, so it shouldn't matter. just use some good degreaser(ie. simple green or purple power) and scrub it real well. if not powder coating, make sure you rough up the outside w/ sandpaper real well then wipe it down w/ acetone so the paint will stick.
maybe someone else has more info on removing the baffle and will chime in.
Re: 22re valve cover baffle removal [Re: Bolosh] #799703 03/25/07 06:24 PM
casper3t Offline
I remember reading a couple of months back where someone removed it by drilling it out and tapping it like you said. But I can't find that post.
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
Re: 22re valve cover baffle removal [Re: Bolosh] #799704 03/25/07 07:42 PM
Stevie Offline
The baffels I've seen are bolted in: 8 or 10mm heads, can't remember for sure. Good gasket sets have these baffel packings in them. I believe their purpose is to trap the water resulting from condensation formed in the cover when the engine is heated-cooled-heated-etc.
If you're worried about re-attaching, just get an older style head cover with the bolts. I believe they will all fit.
'80 4X4 Longbed
Re: 22re valve cover baffle removal [Re: Bolosh] #799705 03/25/07 10:23 PM
P
poolville02 Offline
I took mine out. They weren't rivets they were pins and the baffle was press fit on them. I think I remember prying off the baffle with a plethora of screwdrivers and pliers lol. In the process I bent it up pretty good, but it all hammered back down when I reinstalled it.
Mine had a lot of carbon buildup. If I had to do it over again I don't think I would bother taking it off. Theres nothing underneath it except empty cavities . My rebuild kit came with the proper gasket to replace it with.
Also, I tried everything to get the carbon to come off, 3000psi washer, soaked in mineral spirits for a week, wire brush, ect.... Only thing that remotely worked for me was soaking it in simple green and using a very small wire bush attachment on a drill.
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
Re: 22re valve cover baffle removal [Re: poolville02] #799706 03/26/07 01:46 PM
Bolosh Offline OP
Thanks for the input guys <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 22re valve cover baffle removal [Re: Bolosh] #799707 05/03/07 09:06 PM
Bolosh Offline OP
Hey guys, just thought I'd update the thread with pics of the valve cover that I got powdercoated. It came out really nice!
Re: 22re valve cover baffle removal [Re: Bolosh] #799708 05/15/07 05:52 PM
Bolosh Offline OP
Just a little update in case anyone else wants to do this. It was the earlier '80's models that had the baffle attached to the valve cover with bolts. There were only 8 on them vs. 10 mounting points on the later models.
The bolts are part no. 90080-11691 and come with the integrated washers. They are anywhere from $.72 ea. online to $1.00 at the dealer.
The heads of the pins originally used were drilled out/ground off, then you have to drill/tap new 6-1.00 holes and the factory bolts will thread right in. Of course you could use anything similiar, but this is what was used at the factory so to speak.
Re: 22re valve cover baffle removal [Re: Bolosh] #799709 05/15/07 09:16 PM
cktoy Offline
great job ,thats real nice <img src="/forums/images/graemlins/cheers.gif" alt="" />
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6361 MB (Peak: 0.7417 MB) Data Comp: Off Server Time: 2026-11-02 08:02:44 UTC
