Steering Hose Replacement #799775 03/24/07 07:03 PM
cbb1162 Offline OP
I got the steering hose extended by a hydraulic shop after the 3 in. body lift but didn't get a high pressure fitting put in it so now it leaks. I'm looking at getting some parts from Earl's American Street Rod. They have some adapters but I didn't know what size. Does anyone know which size I would need to convert to?? Check the link below to see options.
web page
This is for a 95 Rodeo with auto. tran.s
Thanks Carl
95.5 Isuzu Rodeo
3.2 Automatic 4x4
High flow cat.
Dynomax muffler
Calmini high flow intake
Independent 4x 3" Body Lift
305/70/R16's Dunlop Mud Rover M/T's
Indy 4x 3" Suspesion Lift
Re: Steering Hose Replacement [Re: cbb1162] #799776 03/25/07 02:16 PM
RobG Offline
why did you extended the power steering for a 3" BL... you shouldn't have needed to do that?
-Rob
Re: Steering Hose Replacement [Re: RobG] #799777 03/25/07 08:42 PM
cbb1162 Offline OP
Because the return line was to short after installing the lift. It even suggested that you would need to do it in the instructions of the lift. Once I got the lift on the return line didn't won't to stay on so I rigged it till I could get it to a shop and have a longer line added. So I figured instead of trying to have someone else make it I could buy the pieces parts to make my own, maybe for even less than someone weilding the OEM connetor to another line with a high pressure crimp.
Does anyone know which one would fit???
Carl
95.5 Isuzu Rodeo
3.2 Automatic 4x4
High flow cat.
Dynomax muffler
Re: Steering Hose Replacement [Re: cbb1162] #799778 04/07/07 06:35 PM
CPOM Offline
Isuzu steering box fittings are 14 x 1.5mm inverted flare
CHRIS
98 Amigo, 92 Pup
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6004 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-06-20 21:41:41 UTC
