Broken Timing Chain???? #799779 03/24/07 07:55 PM
sdjeremyv Offline OP
I have an 87 SWB. Has only 107k orig. Last week started making a tappit kind of noise like it was low in oil( only like 1/2 qt.) Couldn't pinpoint exact location of the noise then the next day on the freeway I let off the gas and it dies. It compression started no problem but now the tap had become a clang bang....Pulled into closest parking lot and shut it off. I've got it home now.I am hopeing that someone here could toss out some ideas before I tare apart. And either go in the wrong direction or waste my time.
Thanks!!
Re: Broken Timing Chain???? [Re: sdjeremyv] #799780 03/24/07 11:54 PM
toddstidham1 Offline
maybe a chain tensioner or guide? <img src="/forums/images/graemlins/scared.gif" alt="" /> Removing the valve cover will let you look down the front cover with a flash light.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Broken Timing Chain???? [Re: sdjeremyv] #799781 03/30/07 12:09 PM
Quinnchuck Offline
Check & see the silent shaft chain is still there? there is an adjustment for chain tensioner.If there's no oil pressure could be the chance of the silent shaft chain being broke or jumped of spockets <img src="/forums/images/graemlins/scared.gif" alt="" />
"YOU CAN ONLY LEARN SO MUCH KNOWLEDGE IN A LIFETIME..BUT IMAGINATION IS WHAT MAKES THE WORLD GO AROUND"
89 POWER RAM D50 4X4 XCab 2.6L
91 Grand Prix GTP 3.4L
87 Jeep YJ Laredo 4.0L EFI
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5938 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-05-29 16:09:23 UTC
