The reason you drop the oil pan... #799812 03/24/07 09:17 PM
Bolosh Offline OP
I'm rebuilding my 22re after the ***** hit the fan. My '89 4x4 up and died on me while going to work one morning, and I quickly found that the chain had popped off the cam gear, and the cam gear was cracked. After removing the timing chain cover I found that the oem chain guides were obliterated and only about 50% of them were still attached to the front of the block. The chain was eating through the driver side chain guide bolts and the chain cover. Its no wonder it popped there was so much play in it. This is the reason you drop the oil pan in cases like this.
The po of this truck must have been special... I'm not even sure what some of the stuff I found in the bottom of the pan is! And a Penny!!??? You've got to be kidding!! Anyway, I just thought I'd share the treasures I found smile
Can anyone tell me if that spring was actually supposed to be somewhere in the motor?
Re: The reason you drop the oil pan... [Re: Bolosh] #799813 03/24/07 10:15 PM
RatLabGuy Offline
I think the spring is intended to keep the penny company.
Wow.
Question Reality.
Re: The reason you drop the oil pan... [Re: Bolosh] #799814 03/24/07 11:07 PM
mosk Offline
Spring looks like the timing chain tensioner's internal spring, perhaps from a previous tensioner? But yes, you should drop the pan for exactly the reasons illustrated by your picture.
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
Re: The reason you drop the oil pan... [Re: Bolosh] #799815 03/24/07 11:34 PM
O
Omega Supreme Offline
Your truck is worth more than you thought!!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: The reason you drop the oil pan... [Re: Omega Supreme] #799816 03/25/07 01:06 AM
Bolosh Offline OP
Haha no kidding.
Re: The reason you drop the oil pan... [Re: Bolosh] #799817 03/25/07 03:02 AM
missouriman Offline
lol... what year is the penny.
might give a clue as to if the motor was built with it in there or if it came some time after...
holy cow.. amazing what all can be in a motor and it still run..
Re: The reason you drop the oil pan... [Re: Bolosh] #799818 03/25/07 02:16 PM
babyhuey Offline
I would say the spring cam from oil pump relief valve,although I dont have a clue how it could have made it through the gears.I would say the penny was from the philly mint. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: The reason you drop the oil pan... [Re: Bolosh] #799819 03/25/07 08:33 PM
RichK Offline
Not sure what the spring is for, but my mechanic did the same thing and he found most of my old clutch in the pan, the timing chain guide and a whole lot of other unidentifiable crap.
1993 4X4 Toyota Pickup XtraCab
22re (ATK Remanufactured)
Re: The reason you drop the oil pan... [Re: babyhuey] #799820 03/25/07 09:39 PM
mosk Offline
Yeah, now that I think of it, I think this is the correct answer.
Jeff Moskovitz
Jeff's 22R-TE page
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6248 MB (Peak: 0.7279 MB) Data Comp: Off Server Time: 2026-06-23 01:18:01 UTC
