Re: Gen I to Gen II compatability thread
[Re: MojaveJack]
#799976
05/01/13 09:03 PM
Hi, all. A newbie Gen I owner here. Sorry to resurrect a very old thread, but was wondering on the upper control arm swap, does the Gen I ball joint still fit, or will I have to use a Gen II ball joint, as well? Thanks! IIRC, the Gen Is are pressed in and the Gen IIs are bolted. The FSMs should confirm or deny this statement...
[Re: MojaveJack]
#799977
05/02/13 03:40 AM
the Gen 2 has a gen 2 ball joint. The advantage is the Gen 2 is easily replaceable(nut and bolts) , the gen 1 is a remove arm and press in the balljoint.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#799978
05/16/13 10:31 PM
Great! Thanks for the info!
[Re: justice]
#1079835
01/11/16 02:43 PM
Would 4runner manual hubs fit gen 1 months?
[Re: justice]
#1079840
01/11/16 08:22 PM
No, the splines and spacing are different.
[Re: justice]
#1105786
10/25/20 01:59 AM
Fan ? My fan is cracking, what others fit ?
Gen1 3.0l V6 with automatic transmission.
Thanks.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door. Disabled Driver.
