Page 10 of 10 1 2 8 9 10
Re: Gen I to Gen II compatability thread [Re: MojaveJack] #799976 05/01/13 09:03 PM
Hi, all. A newbie Gen I owner here. Sorry to resurrect a very old thread, but was wondering on the upper control arm swap, does the Gen I ball joint still fit, or will I have to use a Gen II ball joint, as well? Thanks!
IIRC, the Gen Is are pressed in and the Gen IIs are bolted. The FSMs should confirm or deny this statement...
Re: Gen I to Gen II compatability thread [Re: MojaveJack] #799977 05/02/13 03:40 AM
KrzyDav Offline
the Gen 2 has a gen 2 ball joint. The advantage is the Gen 2 is easily replaceable(nut and bolts) , the gen 1 is a remove arm and press in the balljoint.
dave h.
Re: Gen I to Gen II compatability thread [Re: KrzyDav] #799978 05/16/13 10:31 PM
MojaveJack Offline
Great! Thanks for the info!
Re: Gen I to Gen II compatability thread [Re: justice] #1079835 01/11/16 02:43 PM
monterito88 Offline
Would 4runner manual hubs fit gen 1 months?
Re: Gen I to Gen II compatability thread [Re: justice] #1079840 01/11/16 08:22 PM
No, the splines and spacing are different.
Re: Gen I to Gen II compatability thread [Re: justice] #1105786 10/25/20 01:59 AM
Trailmonkey Offline
Fan ? My fan is cracking, what others fit ?
Gen1 3.0l V6 with automatic transmission.
Thanks.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door.
Disabled Driver.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6201 MB (Peak: 0.7055 MB) Data Comp: Off Server Time: 2026-05-29 20:02:39 UTC
