Snorkel Kit #799979 03/25/07 01:50 AM
Monty n Guate Offline OP
Hey guys,
Anyone know of snorkels out there for the 2.7ltr 4cyl. I know that ARB does one for the 6cyl.(Could it be modified?) Or are there other options. I would prefer something premade for asthetics(OK call me lame I prefer to keep things looking good)Any help would be appreciated.
Don Iler
97 4cyl. Tacoma
OME 881s, N91s, Alcan AALs, Rancho 9k rear shocks
4.56 gears
32x11.50 Procomp ATs
Re: Snorkel Kit [Re: Monty n Guate] #799980 03/25/07 06:33 AM
krickett686 Offline
The ARB snorkel can be modified for the 4 cyl from what i've been told. When i did my snorkel, i decided that spending $300 for something i'd have to modify anyways was stupid so i just built my own. Looks just as good at 1/3 the price.
Check it out:
http://4wdtoyota.com/Snorkel_Article/
Re: Snorkel Kit [Re: Monty n Guate] #799981 03/26/07 04:08 AM
Jeff the marmot Offline
I see that you're adding this for aesthetics and just I wanted to add the clarification to this thread that the primary reason why anyone should add a snorkel to a Tacoma or 4Runner is for aesthetics - or maybe a "cold air intake". It isn't particularly function for deep water crossings since the door seals leak pretty bad in deep water and there's plenty of electronics at a fairly low level. I've seen it a couple times on different Toyotas.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Snorkel Kit [Re: Jeff the marmot] #799982 03/26/07 05:47 AM
krickett686 Offline
I would disagree Jeff. I've forded creeks in my Tacoma with water halfway up the doors with my snorkel. Not a drop of water came into the cab. The electronics in the engine compartment are all up high and the ECU in the cab is located atop the transmission hump in the center of the dash. This is higher than the passenger kick panel location in the pickups.
I've seen numerous pickups on the other hand fill up with water after getting stuck in deep water holes and water crossings. My brother's pickup tipped over on the passenger side in a mud hole w/ the doors and windows closed and the cab filled with water. We unplugged the ECU, cleaned out all the connectors, and started it back up.
A snorkel for "aesthetic reasons" is pretty stupid in my opinion.
Re: Snorkel Kit [Re: krickett686] #799983 03/27/07 03:55 AM
Actually,
I would only use it for asthetics and possibly cold air intake(I live in a desert). So it's interesting you mention that.
Thanks
Don Iler
97 4cyl. Tacoma
4.56 gears
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6747 MB) Data Comp: Off Server Time: 2026-06-07 04:49:02 UTC
