22R Rebuild Cost #800123 03/25/07 02:30 PM
dieseltrooper Offline OP
Spring is here and i'm ready to rebuild a 22R for my 83 project. Those who have "been there,done that", what's a fair cost estimate for the machine work (big-valve head) and engnbldr kit?
Re: 22R Rebuild Cost [Re: dieseltrooper] #800124 03/25/07 02:50 PM
Stevie Offline
Just had it done!
Brought the crank in to be mic'd, and it was real marginal, so we ground it down to 1st oversize. With the bearings, it was $135 here in San Diego.
The head was cleaned, pressure-tested, resurfaced, valves/seats reground, guides replaced, and a sparkplug helicoil installed: $284, but man it looks GOOD!
The block looks ok, so I'm just replacing the freezplugs and cleaning it up as best I can. $10
Gasket set was $25 off fleabay. Had a spare crank pilot bearing to put in myself: $10.
Now I just need time to put it all together.
<img src="/forums/images/graemlins/notooth.gif" alt="" /> And it's fun too!
'80 4X4 Longbed
Re: 22R Rebuild Cost [Re: dieseltrooper] #800125 03/25/07 09:38 PM
P
poolville02 Offline
Heres what I paid for machine work on my 22r:
Vat & MF block.................$60.00
Bore & Hone block..............$60.00
Pin bushings & hone to fit.....$40.00
Polish crank...................$25.00
Check Rods.....................$16.00
Balance........................$125.00
Deck block.....................$60.00
Total..........................$386.00
Add in the rebuild kit, cover, headbolts, cam, RV head, from EB...approx $900.00. Plus all the little extras that add up: bolts, RTV, hoses, carb rebuild, tools, fluids, ect, ect...
I've got a drawer full of receipts that Im scared to add up lol. Some can do it cheaper I'm sure, really just depends on how thorough you wanna be...
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
Re: 22R Rebuild Cost [Re: poolville02] #800126 03/25/07 10:42 PM
dcg9381 Offline
I need to move to poolVille..
The number comes out about the same though.. $750-$1200.
22REturbo.net
1988 4Runner
Re: 22R Rebuild Cost [Re: dcg9381] #800127 03/25/07 11:18 PM
Good info... <img src="/forums/images/graemlins/kewl.gif" alt="" /> What's involved with the balancing? rods/pistons within a gram of each other?
I'm sure the misc will eat my lunch by the time it's done. I have a hoist, but still need an eng stand...
Re: 22R Rebuild Cost [Re: dieseltrooper] #800128 03/25/07 11:32 PM
Elbow_Greese Offline
Just an FYI, Autozone has a good stand for about $40 last I looked.
I haven't the slightest idea what my rebuild cost. It was done a couple years ago and I have conviently forgot the numbers <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: 22R Rebuild Cost [Re: dieseltrooper] #800129 03/26/07 02:09 AM
kewlynx Offline
We posted this up a little while ago; for your reference.
Takin' the plunge
**ubi apis- ibi salus**
Re: 22R Rebuild Cost [Re: dieseltrooper] #800130 03/26/07 02:18 AM
P
poolville02 Offline
yea thats all the balancing was...I read that it wasnt really necessary as the 22r's are supposed to be pretty good from the factory but my machinists had to take quite a lot of material from the rods to get them within spec. The Rock pistons from EB were nearly perfect outta the box.
I hear you about that "misc" category!! I got me a cheapo stand from harbor freight and used their 20% off coupon...it works fine and held my 390 ford but dont even think about trying to spin a V8 on that thing with out getting injured lol I know from experience! <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: 22R Rebuild Cost [Re: dieseltrooper] #800131 03/31/07 03:45 PM
A
aptech Offline
mine cost me aboat 15oo hundred all together. had to replace a lot of hardware and i would recommend you buying two sets of gasket. the sleeve repairs for the rear and front bearings on the crank. rear main bearing seal and housing gasket. red treadlocker, and lots of pictures will
save a lot of grief at the end with extra bolts you find.
Re: 22R Rebuild Cost [Re: dieseltrooper] #800132 03/31/07 08:24 PM
dcg9381 Offline
I've done one motor w/o balancing and one with balancing.
When balacing, I provided the entire rotating assembly - front pulley, flywheel, and some shops even want the clutch.
You can do it either way, but the motor I had balanced is significantly smoother at idle... Whatever that's worth.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6337 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-06-10 01:48:36 UTC
