Brake Warning Light Staying On #800171 03/25/07 06:13 PM
toosexxy Offline OP
I have a 90 Isuzu Spacecab 4wd,I have restored the truck.replacing and rebuilding many parts.The brake system is completely redone,I have bled the system several times so ther is no air,but I can't get the warning light in the dash to go out.Is there something that has to be reset on these trucks?thks for any help.
Re: Brake Warning Light Staying On [Re: toosexxy] #800172 03/26/07 10:22 AM
Bansil Offline
couple quess's here.
do you have the low pressure switch and low fluid switches plugged in correctly?
Is this the same light as the e-brake light.
not sure if these pertain to yours our not,though.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Brake Warning Light Staying On [Re: Bansil] #800173 03/26/07 01:17 PM
toosexxy Offline OP
Yes I do believe that it is the same light,the e-brake light.I checked the e-brake and it wires are hooked up and the switch appears to be working.The other 2 sensors I am not sure about don't think I have had them unhooked,but who knows might have been that way when I got it.I will have to check them thks
Re: Brake Warning Light Staying On [Re: toosexxy] #800174 03/27/07 01:23 AM
JLEMOND Offline
HAVE YOU CHECKED THE DIAPHRAM IN THE BRAKE MST CYL CAP IT THE RUBBER DIAP, POPS DOWN IT WILL TURN THE LITE ON , JUST PUSH IT BACK IN THE CAP UNTILL IT IS FLAT AND SEE IF THE LIGHT GOES OUT . JERRY
Re: Brake Warning Light Staying On [Re: JLEMOND] #800175 03/27/07 01:23 PM
toosexxy Offline OP
Can't say I looked there before,but I will look and see,tks for the info
Re: Brake Warning Light Staying On [Re: toosexxy] #800176 03/27/07 11:12 PM
rodeo157 Offline
not trying to thread jack you but i have a 95 rodeo with the brake light always on and the rear anti lock light always on. i know i have a sticking rear caliber. what causes this? its off when i start the truck but 1 min later they pop on.
95 rodeo 3.2 liter 5 speed 4 wheel drive. 2" lift. poly bushings. 2 1/4 manderal bent exhaust flow master muff. asin manual hubs, relocated ball joints, custom air intake system
92 rodeo 3.1 2wd auto (wifes)
Re: Brake Warning Light Staying On [Re: rodeo157] #800177 03/28/07 01:05 AM
trooperbc Offline
probably the unequal hydraulic line pressure caused by your sticking caliper. in any case, you will want to take care of that lest you risk overheating the whole wheel brake assembly. have you seen how hot it gets?
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: Brake Warning Light Staying On [Re: trooperbc] #800178 03/28/07 02:22 AM
rodeo157 Offline
its not bad, but when i put new pads on it took alot of force to get that piston back in and the other side was easy, also it makes a horrable noise in reverse
Re: Brake Warning Light Staying On [Re: rodeo157] #800179 03/28/07 07:07 AM
trooperbc Offline
....when i put new pads on it took alot of force to get that piston back in and the other side was easy...
that could very well mean that the brake hose to the caliper on that side is clogged up, which will keep the pad from releasing...
i wouldn't let it go....
//bc
Re: Brake Warning Light Staying On [Re: trooperbc] #800180 03/28/07 04:55 PM
rodeo157 Offline
im going to fix it, i just need a couple weeks to save up for it. its like 80 for the caliper. and right now im in school and only working part time. so ill replace it in about a week to 2 weeks and see what happens.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6374 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-06-10 01:47:53 UTC
