Re: Brake Warning Light Staying On
[Re: rodeo157]
#800181
03/29/07 03:45 AM
On my 90Isuzu the rear disk brakes are also the e-brake,you just can't press the caliper pistons back in you have to screw them back in.when the cables are pulled it turns the screw,tightening the pads to the disk and also keeps the e-brake adjusted
[Re: toosexxy]
#800182
03/29/07 05:53 PM
mine is all weird, i have 4 wheel disc with parking brake shoes. so i have rotors with a drum in the middle. im used to screw in calipers to but these look just like a front one. its a weird setup you dont want. the parking brake shoes are 200 dollers.
95 rodeo 3.2 liter 5 speed 4 wheel drive. 2" lift. poly bushings. 2 1/4 manderal bent exhaust flow master muff. asin manual hubs, relocated ball joints, custom air intake system
92 rodeo 3.1 2wd auto (wifes)
[Re: rodeo157]
#800183
03/29/07 06:08 PM
The difference is because the 95 Rodeo uses the Dana 44 out back where as the 90 Isuzu uses the Isuzu 12 bolt out back. Different brakes between them. The 12 bolt uses the caliper with integrated parking brake while the Dana 44 uses the drum inside disc parking brake.
[Re: Richard Saylor]
#800184
03/29/07 09:29 PM
One more thing to check is the actual switch for the e-brake. I've had cars that have had those stick before (either always on, or never on).
Jeff Mason
Whatever makes you upset in someone else...also exists in you
[Re: Jeff Mason]
#800185
03/29/07 10:50 PM
well on mine when i put the brake on the light gets a little brighter and when i take it off it gets a little dauller. but the anti llock rear light stays same
[Re: rodeo157]
#800186
03/29/07 11:15 PM
well on mine when i put the brake on the light gets a little brighter and when i take it off it gets a little dauller. but the anti llock rear light stays same That sounds like the switch in the master cylinder is saying that it's low on brake fluid. Could also be why the anti-lock light is on too ; if it thinks / or is low on fluid. Richard <img src="/forums/images/graemlins/patriot.gif" alt="" />
#800187
03/30/07 01:59 AM
That must be where General Motors came up with the idea for the 99 and up trucks on there rear.the disk brake with drum e-brake.I haven't played with mine yet to get the light out,busy with one of my ATV's,gotta get everything ready for summer
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6255 MB (Peak: 0.7159 MB) Data Comp: Off Server Time: 2026-06-21 20:24:55 UTCValid HTML 5 and Valid CSS
