aldl on 4ZE1 #800249 03/26/07 12:15 AM
P
parasite Offline OP
Is there an aldl connector on a 88 trooper with a 4ZE1 motor?
Re: aldl on 4ZE1 [Re: parasite] #800250 03/26/07 12:28 AM
strawmyers Offline
Isuzu Moderator
If aldl's are the technical term for code scanners, no... an '88 Trooper would have predated OBDII by quite a margin.
Sean Strawmyer
Re: aldl on 4ZE1 [Re: parasite] #800251 03/26/07 01:17 AM
randii Offline
ALDL = Assembly Line Diagnostic LinkIt should be two wires right near the computer, but I don't recall where Troopers of that vintage kept their Os and 1s. Check on the transmission tunnel between the seats under a console or in the driver's side kick panel.
Randii
Re: aldl on 4ZE1 [Re: randii] #800252 03/26/07 06:11 PM
RT1 Offline
Should be two wires dangling left of the clutch pedal, probably behind the mat; One spade, one socket. When joined
turn the key to the "on" position (not running) and the engine light will flash the code for any anomalies. First code will be "12" (one, one-two) which will flash three times before any other codes come up.
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
Re: aldl on 4ZE1 [Re: RT1] #800253 03/27/07 05:28 AM
thepcguy Offline
On my 1989 Trooper, the connection wires are located under the center console (between both front seats) right behind (toward the rear of the truck) the shifter area.
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: aldl on 4ZE1 [Re: thepcguy] #800254 03/27/07 08:09 AM
O
onetouch Offline
Lift the change tray.
You'll see two wires with spade connectors.
That's what you're looking for.
Jim
89 Trooper, AMC head, Asians, nothing special yet.
Re: aldl on 4ZE1 [Re: strawmyers] #800255 03/27/07 11:35 PM
litnin Offline
ODBI had scanners too.. they were just not as "universal" as
the ODBII stuff.
Being that ODB1 systems were more manufacturer proprietary,
aftermarket parts store code scanners weren't widely made.
The dealers had scanners they could hook up to the
pre-'96 vehicles to read ODB1 codes.
I believe Isuzu's unit was called the TECH-1.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: aldl on 4ZE1 [Re: litnin] #800256 03/28/07 01:23 AM
trooperbc Offline
the OBDI electronic diagnosis used the TECH 1 and of course it was nothing like the consumer versions available for one and all for the 1996-> OBDII. The TECH 1 was from Vetronix (OTC?) and was (is) a complete deal with vehicle specific software program modules, adapters, etc. and reads the autotransmission codes too. and they not only read codes, but provide much more detailed data and with control features as well. and VERY pricey. (i want one)
the TECH 2 is the current configuration for OBDII.
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: aldl on 4ZE1 [Re: parasite] #800257 03/30/07 02:13 PM
P
parasite Offline OP
what about winaldl + custom cable? has anyone managed to get that to work on the 4z engines?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6230 MB (Peak: 0.7100 MB) Data Comp: Off Server Time: 2026-06-22 06:09:56 UTC
