97 rodeo flex pipe
#800441
03/26/07 03:30 AM
my flex pipe is rotted and theres also a leak by the joint after the flex pipe ... anyone know what size flex pipe i need to buy to replace it and is there a gasket needed where the joint is to the right of the flex going backwards ? if so anyone know the gasket size or type needed to replace it too?
97 rodeo 3.2 4wd
Re: 97 rodeo flex pipe
[Re: SOURCE7769]
#800442
03/26/07 04:43 AM
I just had mine replaced, and all they did was cut out the old one and weld a new one in on both sides. It was a little bigger than stock, but whatever. If you want someone else to do it, I would guess about 80 bucks. If you do it, someone else might chime in to answer your q's. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5899 MB (Peak: 0.6381 MB) Data Comp: Off Server Time: 2026-05-29 17:26:04 UTCValid HTML 5 and Valid CSS
