Low oil pressure #800591 03/27/07 12:25 AM
throwin_roost Offline OP
I noticed today while sitting at a light that my oil pressure guage was bottoming out and fluttering and the light was coming on. I checked the oil and it was fine. At cruising speed it seems fine at about 29 psi but at idle it drops all the way. Can I use a higher viscosity oil to help this or do I have big problems. It is a 93 rodeo 3.2. Any help would be much apreciated.
93 Rodeo 3.2L, 3" body lift, 3" Indy4x lift on 33's, flowmaster50, stainless brakes and clutch lines,
Re: Low oil pressure [Re: throwin_roost] #800592 03/27/07 11:59 PM
F
Fujisawa_Rob Offline
I'd get a second opinion, from a mechanical gauge.
2000 Mitsubishi Montero Endeavor, "Katsumi", 138k
1993 Toyota Tercel, backup vehicle, 93k
1989 Isuzu Trooper, "Beniko", R.I.P. at 233k
My 'Genuine Isuzu Parts' decals - for sale
Re: Low oil pressure [Re: Fujisawa_Rob] #800593 03/28/07 01:20 AM
Bigpoppax2 Offline
Yeah you only need about 10 pounds of oil pressure per 1000 RPMs.
x2 on the mechanical gauge.
Joe
Re: Low oil pressure [Re: throwin_roost] #800594 03/28/07 02:05 AM
trooperbc Offline
it could be the gauge or sender, but the fact that the idiot light is coming on is trouble; it's a different sender (switch) and it seems to be confirming your gauge.
stop driving it until you can check it out with the recommended proverbial gauge. such low oil pressure, whether from a failing oil pump or from some other problem, can cause all sorts of damage even sitting there at idle. that idiot light comes on at some rediculously low psi.
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6039 MB (Peak: 0.6598 MB) Data Comp: Off Server Time: 2026-10-21 22:06:43 UTC
