Question on tire size #800595 03/27/07 12:35 AM
Harhir Offline OP
Need to replace the tires on my 2002 Tracker/Vitara soon. The original tire size is 215/70/R15.
Now I want to get a set of AT tires. But there are non in that size.
I could either go with:
- 215/75R15
- 225/70R15
AT tires are available in both sizes. Which size is the better choice? In both sizes the speedometer will be off a little. But not so much as it would be a concern with me.
Would the 225 cause trouble because it is wider by 1cm? Rubbing somewhere when the steering wheel is turned all the way?
2001 Trooper
Re: Question on tire size [Re: Harhir] #800596 03/29/07 12:52 AM
caymin Offline
I have a 1998 Sidekick sport and it has the 225's on it and I do not have any turning issues. One thing to consider is the 215's have less surface friction and less weight which will usually give you better fuel milage.
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5862 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-06-22 06:14:20 UTC
