Battery Tiedown Question #800639 03/27/07 03:59 AM
SpaceManSpif Offline OP
I just noticed that the battery of my truck is not secured down. I bought a battery hold down kit ( you know the two metal poles with the metal/rubber cross bar) but there is no place to hook the poles in. How does everyone else have their battery secured down??
1988 Toyota 4x4 Xtra Cab V6. (Really Faded Silver Paint)
Re: Battery Tiedown Question [Re: SpaceManSpif] #800640 03/27/07 04:01 AM
kewlynx Offline
I've got the stock stuff; jbar on the backside thru the top bar bolted to the core support. You'll see the nutplate.
**ubi apis- ibi salus**
Re: Battery Tiedown Question [Re: SpaceManSpif] #800641 03/27/07 06:30 AM
gueroblanco Offline
i've got a short bungee and a couple "custom " holes <img src="/forums/images/graemlins/notooth.gif" alt="" />
'95 runner 3vze/r150f
Re: Battery Tiedown Question [Re: gueroblanco] #800642 03/27/07 06:49 AM
Scerb Offline
I originally had those two pole hooks, you might have to drill a hole or two to use them and secure them with nuts/washers. I had that setup for about two years until I somehow lost one of the poles and my battery fell onto my fan ripping wires outa the fuse box all while on a trail <img src="/forums/images/graemlins/zombie.gif" alt="" />
Long story short, I'm lazy and I have a bungee chord (make it very tight) and its worked fine in the short term.
-Scerb
Re: Battery Tiedown Question [Re: Scerb] #800643 03/27/07 06:55 AM
gueroblanco Offline
see, nuthin wrong with a little bungee cord duct-tape action!
just kidin, i'm not that gung ho about the nascar fixes but i've had my yota in a lot of steep positions and taken it on a lot of bouncy trails and the TIGHT bungee keeps the battery anchored pretty well. at least, so far...
Re: Battery Tiedown Question [Re: SpaceManSpif] #800644 03/27/07 11:53 AM
cktoy Offline
HEAVY DUTY ZIP TIES <img src="/forums/images/graemlins/notooth.gif" alt="" />
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Battery Tiedown Question [Re: cktoy] #800645 03/27/07 03:14 PM
toyrunner Offline
I have found the Optima batteries are a bit shorter than the wet cell batteries for my truck.
I countered this with a length of 1"x3/16" flat stock and 1" square tubing. I tack welded the flat stock to the tubing and drilled holes in each end of the stock. This utilizes the stock hardware and locations for mounting and the battery is more secure than using a bungee cord.
The new hold down bracket is stronger than the stock unit and doesn't look too bad either <img src="/forums/images/graemlins/notooth.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: Battery Tiedown Question [Re: cktoy] #800646 03/27/07 03:18 PM
Stevie Offline
Go stock Spaceman! Great & simple engineering (i.e.: see your local wrecking yard <img src="/forums/images/graemlins/notooth.gif" alt="" />).
'80 4X4 Longbed
Re: Battery Tiedown Question [Re: Stevie] #800647 03/27/07 03:46 PM
RatLabGuy Offline
I swapped mine with e AFM so now it's on teh exhaust side, had to fab something.
SO I have a tray bolted to teh fender, and a clamping strap that holds it in place. Bright rainbow colored, actually <img src="/forums/images/graemlins/pfft.gif" alt="" /> b/c it was on hand.
Question Reality.
Re: Battery Tiedown Question [Re: RatLabGuy] #800648 03/28/07 05:12 AM
Thanks guys for the info.. I will go bungee for a bit till I work on something more perm..
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6360 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-06-07 04:39:24 UTC
